RV.Net Open Roads Forum: Class C Motorhomes: E450 Cruise Control
 > E450 Cruise Control
Tonijim
MA
Posted: 03/05/12 06:52pm Link  |  Print  |  Notify Moderator
We have an'02 Ford E450 for our '03 BT Cruiser(60,000 miles). On the way to Fl this year our cruise control stopped working. The "On" switch didn't come on and the "Set" switch didn't either. The #6 fuse had not blown.
Any thoughts would be appreciated.
Jim
j-d
Sunny Florida USA
Posted: 03/05/12 08:59pm Link  |  Print  |  Notify Moderator
Only two guesses.
1. Brake pedal release not closing when foot is off the brake
2. VSS (Vehicle Speed Sensor) on top of differential housing failed
A site like BATAUTO.COM (Domestics Forum) might be a better place to ask, or even RV.Net's Tech Forum. This is like most other Ford cruise controls so you don't want to limit the question to just a Class C forum.
If God's Your Co-Pilot Move Over, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100 218" WB
rustell
Mount Vernon Wa.
Posted: 03/06/12 10:59am Link  |  Print  |  Notify Moderator
I'm interested to see if this thread goes anywhere...Most of the time mine doesn't work..I will be driving along and out of the blue hit the switch and it works,usually when we are almost to our destination.. I have never seen the dash indicator light up.
NewsW
US
Posted: 03/06/12 11:06am Link  |  Print  |  Notify Moderator
Easy.
You can do diagnostics, or you can just replace the cruse control deactivation switch.
It is on the lower side of the master cylinder, a screw on / in part.
Note proper job (not hatchet) require complete bleeding of the brakes.
Might as well do a complete brake fluid change at same time.
There was a batch of bad ones that replaced the original fire prone one.
You got one of them.
If the switch is good... then we are onto more complex cases.
dufferdj
Colorado/Arizona
Posted: 03/06/12 11:56am Link  |  Print  |  Notify Moderator
We have both a '96 and '02 Ford Explorer that had recalls on the cruise controls. Took both into the dealer and they were replaced/repaired for free. There was a safety/fire issue with them. Your problem may not be the same, but it would be worth a phone call to your local Ford dealer.
NewsW
US
Posted: 03/06/12 07:06pm Link  |  Print  |  Notify Moderator
That is the cruise control deact switch.
You got one of the replacements, early batches for first few years was a dud, didn't catch fire again, but just failed.
genesimmons
n.c.
Posted: 03/06/12 11:08pm Link  |  Print  |  Notify Moderator
also check turn signals, my turn signal switch went bad on mine and that kept the cc from working
HEMIDAZE
Amelia, OH
Posted: 03/07/12 09:35am Link  |  Print  |  Notify Moderator
There is a safety recall on your unit (and thousands of other Fords) concerning fires as a result of a defective cruise switch. Check with your dealer. If yours hasn't been fixed they will fix it for free.
2002 Jayco Greyhawk 31RB
2011 HHR (picture coming)
Heish
United States
Posted: 03/09/12 01:59pm Link  |  Print  |  Notify Moderator
Hemidaze, Thanks for the information on that. My cc stopped working AND my ABS light is on. Called my local Ford dealer and got an appointment. Hope that is what it is! Love this site!
j-d
Sunny Florida USA
Posted: 03/10/12 05:10am Link  |  Print  |  Notify Moderator
Hiesh,
By all means find out it the cruise control recall was done on your chassis. The ABS light being on and cruise not working points strongly to the VSS having failed, though. At least on pre-OBD2 Fords, 1995 or so and earlier.
The VSS went out in 1992 AeroStar and we lost Cruise, Odometer, and Overdrive. ABS light was ON.
