Terrick down Under
Australia
Hey everyone, where can you get a HEAVY duty radiator to suit my 93 Dually 7.4 auto. I do a lot of towing and carring the TC. Don't want the old girl to get overheated. Its had a 34x19 brass unit. Have tried a 34x17 but it won't keep her cool on the big climbs. Finding a business that will freight to australia is even harder. It has engine oil and transmission also.
Thanks in advance.
jimmyfred
Tx
Terrick down Under wrote: Hey everyone, where can you get a HEAVY duty radiator to suit my 93 Dually 7.4 auto. I do a lot of towing and carring the TC. Don't want the old girl to get overheated. Its had a 34x19 brass unit. Have tried a 34x17 but it won't keep her cool on the big climbs. Finding a business that will freight to australia is even harder. It has engine oil and transmission also.
Thanks in advance.
.............Did GM sell any versions of the 8.1 down under? If yes , I'd see if an 8.1 replacement was available right there within your own borders . An 8.1 radiator maybe the same width as one for a 7.4 but have more cores for additional cooling ! , jf
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
Wills250psd
walnutcove NC
summit racing
StevenH
Michigan
If you still have the 34 x 19 end tanks from the brass unit see if a radiator shop can recore it.
If not a good radiator shop may be able to order the larger (19 verses 17) tanks and build you a replacement radiator.
Good luck
Steve
97 Beaver Patriot 40'
3126 CAT, Allison 3060
Aqua Hot
recycler
michigan
i knew a guy his older chevy truck had a HUGE radiator in it he said it was designed for military pick ups going to desert condtions could see if one is available for your model truck just an idea
1968 franklin 11fk
back to my 93 cummins
goshe
Denver
Ron Davis Racing Products. Can custom build any size and configuration 100% aluminum.Ron Davis Radiators
2007 Duramax, 2009 Hallmark Guanella, 2013 Cougar 28SGS
Trail-Mate
Frederick, MD
Order a replacement from Radiator Barn on the web. It will be an all aluminum one and will cool much better then the stock Brass Copper one. Also if you want it to run cooler. Install Headers with good flowing Cat and Cat back Single setup. and install a 190 degree Thermostat. I made all these changes on a 93 K2500 Suburban 7.4 (454 TBI ) that towed a 10,000 lb trailer. Make a huge difference. The radiator alone made some. The headers and new exhaust made the most difference.
1997 Ford F250 Extended Cab, 7.3 Diesel, 8 foot bed.
Reese 16K Hitch
(Moved into Shed) Hensley Arrow
Jordan Brake Controller, Hensley TruControl Gold Shelved.
Open Range 5th Wheel, Roamer RF392 BHS
Happy Camping !!
nm1oqrz
Trumbull CT
Hello All. I have a 1989 GMC 1 ton 7.4L dually and I put a radiator made for the GMC diesels as they are bigger.
Happy camping nm1oqrz
RobertRyan
Australia
jimmyfred wrote: .Did GM sell any versions of the 8.1 down under? If yes , I'd see if an 8.1 replacement was available right there within your own borders . An 8.1 radiator maybe the same width as one for a 7.4 but have more cores for additional cooling ! , jf
No they did not sell versions of the 8.1. GM Holden has the US sourced 6.2 V8 in it's cars and utes. All other variants of GM V8's imported privately.
JoeChiOhki
Sauvie Island, OR
Trail-Mate wrote: Order a replacement from Radiator Barn on the web. It will be an all aluminum one and will cool much better then the stock Brass Copper one. Also if you want it to run cooler. Install Headers with good flowing Cat and Cat back Single setup. and install a 190 degree Thermostat. I made all these changes on a 93 K2500 Suburban 7.4 (454 TBI ) that towed a 10,000 lb trailer. Make a huge difference. The radiator alone made some. The headers and new exhaust made the most difference.
I've always wondered about that, given that copper has a higher heat dissipation rate than aluminum.....
CB Channel 17 Redneck Express
