RV.Net Open Roads Forum: Who uses a gas TV with their 5th wheel?
 > Who uses a gas TV with their 5th wheel?
Page of 5
zackyboy3rs
Eastern North Carolina
Posted: 03/06/12 04:38am Link  |  Print  |  Notify Moderator
I have a 2500HD gasser. How would it perform with a 10000 5th wheel? Performance, gas mileage and any other advantages or disadvanges I would have. thanks.
2010 Jayco Select 29L
2009 Chevy Silverado LTZ 2500HD 6.0L, 3.73, Gas sipper
Ranger Smith
Wherever the rig is parked
Posted: 03/06/12 04:45am Link  |  Print  |  Notify Moderator
I pulled a 12k with a 2006 GMC 2500HD with the 6.0. It pulled OK but on hills it was horrible. I didn't like the RPM's required to get me up the hill. Some areas I would slow down to 45 by the time I got to the top. Love the RAM won't go back.
Steve
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
mobilcastle
OH
Posted: 03/06/12 05:11am Link  |  Print  |  Notify Moderator
It will work but I doubt you will like it. Extremely high RPM to get to the power band and 8-9 MPG. You might want to go lighter-10K loaded.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
DSteiner51
Wooster, Oh
Posted: 03/06/12 05:30am Link  |  Print  |  Notify Moderator
Me. No problems.
D. Steiner
The sooner I fall behind, the more time I have to catch up.
gmcsmoke
Butler
Posted: 03/06/12 05:38am Link  |  Print  |  Notify Moderator
9k with an avg 8-9MPG. It definitely likes to wind out but it does a good job.
archie780
Edmonton
Posted: 03/06/12 05:46am Link  |  Print  |  Notify Moderator
* This post was edited 04/26/12 08:50pm by archie780 *
therink
Rochester
Posted: 03/06/12 05:47am Link  |  Print  |  Notify Moderator
I do. See sig below. I wouldn't full time with this set up, but it works fine for me as a daily driver and tows well for my needs. 4:10 axle makes a big difference with the gasser.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
mudmaker
Iowa
Don't be scared of the rpm's. And yes the mileage will be a little low. I don't think I'm quite at ten k for weight but it's probably close. It gets me where I need to go with no problem.
Recently purchased a diesel but it's for business and I haven't pulled a thing yet.
Glen and Loretta
Marc, Jake, and Kirsten
Keystone Cougar 326MKS
2013 GMC Terrain
12 Silverado 3500 SRW quad 6.6 Dmax
03 Dodge 3500 DRW quad 5.9 cummins
Yamaha EF2400is gen
swampeagle
Posted: 03/06/12 05:58am Link  |  Print  |  Notify Moderator
Before you buy a diesel research the cost of maintenece, cost of oil Change fuel filter air filter etc. Unless you tow a lot of miles you may be better off with gas.
Wills250psd
walnutcove NC
Posted: 03/06/12 06:13am Link  |  Print  |  Notify Moderator
lots of people do it and are very happy, some of them have also never used a diesel. If its what you have use it!!! go camping. will
Page of 5
