RV.Net Open Roads Forum: Tech Issues: Odor control for kitchen grey water tank
 > Odor control for kitchen grey water tank
JohnnyEm
Andover MN USA
Posted: 03/06/12 05:47am Link  |  Print  |  Notify Moderator
As many of you know the kitchen grey water tank can be more stinky than the black water tank. I've used the Thetford Grey water odor control additive in the past. A friend of mine pours vinegar in her tank. What other methods or products have been successful for you? BTW I keep the valve closed since our park up in the north woods doesn't have on-site sewer facilities.
John
badboy368
OHIO
Posted: 03/06/12 05:49am Link  |  Print  |  Notify Moderator
Treat it, wash it, clean it just like the black tank and problem solved.
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
coolmom42
Middle Tennessee
Posted: 03/06/12 06:03am Link  |  Print  |  Notify Moderator
I would put a couple of cups of bleach in it, let it sit for a few days, then dump, and rinse thoroughly. Then add about 1/4 cup of bleach every few days. Sounds like you are letting it sit for several days unused and un-dumped, of course it's going to stink. If you are not using it a lot, your traps could be dried out and letting the odor up in the camper.
2006 Toyota Sienna
Single empty-nester in Middle TN
tandkj
Full timer
Posted: 03/06/12 06:08am Link  |  Print  |  Notify Moderator
I don't understand how the smell is getting past the under sink trap. If there is water in the trap it is impossible for the smell to come past the water. I would start there by making sure there is water in the trap.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
mguay
Northern NH
Posted: 03/06/12 06:12am Link  |  Print  |  Notify Moderator
The diaphragm in the vent under the sink may be defective.
Real Trucks wear Training Wheels!
JohnnyEm
Andover MN USA
Posted: 03/06/12 06:55am Link  |  Print  |  Notify Moderator
First of all - bleach is a big no no. It eats up the valve seals.
The RV is in continuous use. I do reverse flush the tank every 30 days. I dump the kitchen tank into a "blue tank on wheels" every 5 days. This is when I notice the odor - it's horrendous both when dumping into the blue tank and when emptying it into the dump station.
I'll check out that check valve on the vent under the cabinet.
rockhillmanor
On the Road
Posted: 03/06/12 07:13am Link  |  Print  |  Notify Moderator
I too am parked without hookups. I am allowed to dump gray water. I keep the valves closed and dump when full like you do. Since this water is being dispersed right by my MH I MAKE SURE it smells nice when dumped!
If you have a Publix grocery store they have a great orange cleaner for a couple of bucks that I pour into the gray tank and it takes care of all odors. Comes in a quart bottle. I also do 'not' allow food stuffs and/or any type of grease/fats go down my MH drain.
I 'personally' do not use any product with the word 'sol' in it.
If you don't have a problem with it, Mr. Clean, Lysol, Pinesol and generic versions of them will as well to keep odors at bay and keep your tank clean, and are more economical than Thedfords tank cleaner. Although I do faithfully use Thedfords once a month or so as it cleans the sensors too.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
mavapa
Rome, Ga, USA
Posted: 03/06/12 07:32am Link  |  Print  |  Notify Moderator
I have had some success using liquid, scented fabric softener in the holding tank. Sometimes the gray water smells pretty good. But, on the other hand, sometimes it doesn't. I'm not sure what the difference is, since the same stuff goes into it every time.
gbopp
The Keystone State
Posted: 03/06/12 07:42am Link  |  Print  |  Notify Moderator
x2. Find out where the smell is coming from should be your first concern.
pianotuna
Regina, SK, Canada
Posted: 03/06/12 02:30pm Link  |  Print  |  Notify Moderator
Hi,
Use a strainer when dumping water down the sinks. It keeps the grey water tank a lot nicer.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
