RV.Net Open Roads Forum: Truck Campers: Where Do You Put Your Honda Generator?
 > Where Do You Put Your Honda Generator?
Page of 5
Reddog1
El Dorado, CA
Posted: 03/07/12 11:23pm Link  |  Print  |  Notify Moderator
Buzzcut1, how far from the TC is a built-in generator? How many exhaust pipes have no odor?
Wayne
Reddog1
El Dorado, CA
Posted: 03/07/12 11:35pm Link  |  Print  |  Notify Moderator
Briand wrote:
Another that cable locked to jack.
Never had a problem with exhaust, but not really all that concerned since I have CO alarm.
Would like to see close up of jack mounted genny rack.
I too have a CO alarm, but must admit, I smell the exhaust from gas engines. With my vehicle windows down, I smell exhaust fumes at stop lights when in the city.
Tomorrow, I will either post close up photos of my mount, or find links. Bigfootford may have photos of his.
Wayne
bcbigfoot
Okanagan
Posted: 03/08/12 11:12am Link  |  Print  |  Notify Moderator
I just got my Honda box mounted yesterday, I puttered away off and on making it this winter. I still have miss. to do to it. I will not run the gen. with the gas in the box, just a place to carry it, I may build a rack on the ladder to hold a gas can for extended running. Thanks to Reddog and Luv2skyski for some great ideas and inspiration.
* This post was edited 03/08/12 10:21pm by an administrator/moderator *
RichieC
Gig Harbor - Cave Creek
Posted: 03/08/12 07:23am Link  |  Print  |  Notify Moderator
The safety instructions that came with the Honda state to keep it 30feet away from open windows and doors.
I made up a plastic coated cable wire with looped ends which can padlock the generator to the truck.
The camper 30 amp power cord is about 30 feet long and I use it at its full extension.
Buzzcut1
Norcal
Posted: 03/08/12 07:42am Link  |  Print  |  Notify Moderator
Wayne
If the generator is regularly serviced, then then propane units are relatively safe as they should burn the fuel completely and produce little if any CO. These units were designed to operate in the close proximity of a living area.
Portable gensets are not designed to be used in or next to an enclosed living area. They are built to deliver power not to give clean exhaust at all times
I keep my Honda 2000 at least 30' from my rig when in use
It's just not worth it to me to risk the consequences
03 F350 Diesel 4x4 Crew Cab long bed, 08 Lance 1055, Rancho 9000xl, Air Lift air Bags, Torqlift tiedowns,stable loads, super hitch, 48" super truss, Toyo 285/75R16 Opencountry HT
bobndot
NY
Posted: 03/08/12 06:26am Link  |  Print  |  Notify Moderator
I never owned an rv with a built in gen. I really never measured anyone's exhaust distance to a door. The few that i have seen have been located away from doors and the windows close to them have been solid sealed windows that do not open.
Carbon Monoxide is lighter than air therefore it will have a tendancy to move upward. That's how it kills people in upstairs bedrooms in homes when a car is running in a lower level garage. However out of doors wind can move it in any direction.
I was speaking to a MH rep at a dealership about RV tech stuff . During that conversation he stated on board gens. need to be installed and operated under codes like RVIA, NFPA. Away from a window that opens and gas tank fill locations.
I was able to find : ANSI 119.2 / NFPA 501c NFPA 1192 .
I would be concerned about making a modification involving something like a generator where it carries fuel a HAZ-MAT issue , grounding specs for electrical codes, fireproofing barriers between the working gen. and the rv and exhaust codes.
Anytime there is a fatality like carbon monoxide death, there is a homicide investigation lead by a D.A. who is looking for any kind of broken law, code or rule so he can hang the person who caused the death of another. Personally, i do not want to be in that position. I don't modify things , i let the mfg. accept responsibility to be liable.
I like the carrying method and the mount to carry it , a good job was done constructing it . After seeing your mounting rack, i sometimes transport my gen. on a rack too.
I would not feel comfortable operating at that location because it is a modification that has strict codes to follow and its too involved for me . I do not know much about electricity and lightning. I would not know how to ground the gen. using it like that. Faraday cage and lightning.
RVIA codes are listed on this site. http://www.cumminsonan.com/www/pdf/rv/f-832.pdf
http://www.myoldrv.com/?p=452
RV deaths do occur from carbon monoxide: http://www.foxnews.com/story/0,2933,358109,00.html
Page of 5
