RV.Net Open Roads Forum: Class A Motorhomes: Buying Advice -- 1999 American Eagle
 > Buying Advice -- 1999 American Eagle
michahicks
Waterford/Gaylord, Mi
Posted: 03/07/12 06:13am Link  |  Print  |  Notify Moderator
I worked as an RV tech for quite a while, but I STILL had the coaches I was interested in checked out by a good truck shop. I felt I didn't know near enough about them as well. I made it a point NOT to use the one the owner used as I wanted a completely independent survey.
The coach's condition and documentation should tell you an awful lot when you get to see it. I would plan on spending an entire day checking that and what you can on your list? Being forced to hurry through that is something to avoid. Have the owner fire up the 'fridge so it's all settled down prior to your arrival. That's one place I wouldn't want to find a surprise.
1997 38' HR Endeavor, 275 Cat, Freightliner
2003 CR-V Toad, Blue Ox, Ready Brake
Cat320
Somewhere in the USA
Posted: 03/07/12 05:58pm Link  |  Print  |  Notify Moderator
The AC Eagle is a great coach and has been for years. The new ones start at $525k.
Jim@HiTek
Gresham, OR, USA
Posted: 03/08/12 03:20pm Link  |  Print  |  Notify Moderator
That's great. Snds like a great coach.
BTW, would you mind telling us what the charge for the inspection was? That would have been $350-$450 6 years ago. Wonder what it is now?
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
Hatman
Columbus, OH
Posted: 03/08/12 03:17pm Link  |  Print  |  Notify Moderator
Here's the latest update:
Inspector spent the better part of the entire day with the coach (Affordable RV Inspection Service, Wayne Delisse, Fort Mill, SC 704-975-4034). He's going to e-mail the entire report and photos when he gets back in the office tomorrow morning, but he uncovered a few areas of concern:
1) Slide sticking. This didn't happen when I saw the coach, but he had problems with the slide extending. Said it would start, move a few inches, then stop. Press the switch again, then same thing. After a couple of times, it would then extend all the way. Said it was probably the switch, the control board, or the motor, none of which was too much $$$.
2) Hydraulic fluid leaking from a rear jack line. Jack operation not affected.
3) Transmission cooler line leaking.
4) Fridge not operating on LP.
Overall, the inspector was very impressed with the coach, and felt it had been well-maintained. There were a few small signs of past water incursion, but nothing major and nothing current, and not out of the ordinary for a 13-year-old coach.
The seller said he will take the coach to shop and take care of the above items, and he still needs to get the new tires installed. So once that's done, I should be driving to SC to pick up my new (to me) coach.
Thanks again for the advice and encouragement.
Hatman
Columbus, OH
Posted: 03/08/12 03:35pm Link  |  Print  |  Notify Moderator
It was $300 plus 50 cents a mile travel. It was 184 miles round trip, so the total was $392.
Jim@HiTek
Gresham, OR, USA
Posted: 03/08/12 03:38pm Link  |  Print  |  Notify Moderator
Yep, right there in line with what I've read about the service. The feeling of confidence you get from having a professional check it out for you is definitely worth $400.
