RV.Net Open Roads Forum: Class A Motorhomes: ISL
B's Bunch
Shelbyville, TN. USA Why live any where else?
Posted: 03/06/12 04:17pm Link  |  Print  |  Notify Moderator
When is an ISL an ISL. is it the same block as uses the same filters as in oil and air filters. Mine is a 370hp the one i am considering is a 450. I assume it is but who wants to guess in this age. Reason for asking I have several filters bought at once for the 370 and dont want to let them go if they will also work on the ISL 450hp. Thanks Larry
Larry,Brenda,Travis,Jarred & MEME the Boston Terror TheBunch 2011 American Coach Revolution 42T
steveownby
Cosby, TN
Posted: 03/06/12 04:29pm Link  |  Print  |  Notify Moderator
The oil filter and the secondary fuel filter (on the side of the engine), are the only filters that are supplied by Cummins. The primary fuel, air, and coolant ifilters are chassis builder items and may or may not be the same.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
The Texan
Meridian, Idaho
Posted: 03/06/12 04:40pm Link  |  Print  |  Notify Moderator
A little more information please....I have NOT heard of a 450HP ISL, but have heard of a 450HP ISM. What year are you talking about and if a used coach, what model and year?
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
B's Bunch
Posted: 03/06/12 04:53pm Link  |  Print  |  Notify Moderator
Which is the purpose of my question. 2011 model new. salesman states isl which i thought you could turn one up but when does it reach its limits. Spec for build shows CMNS 450 no model # I will know for sure this weekend but not until then as I will be looking at it. I got filters on sale thru NAPA and if can be used would be foolish to let them go. Just curious. Thanks American Revelution 2011 Larry
chastho
arkansas
Posted: 03/06/12 05:00pm Link  |  Print  |  Notify Moderator
The ISL is now a 450HP, up from the 425HP which was the 400 ISL.
steveownby
Cosby, TN
Posted: 03/06/12 05:31pm Link  |  Print  |  Notify Moderator
With the addition of the urea system on the 2010 EPA engines, Cummins is rating the ISL at 450 hp. This also required Allison to bump up their max rating on the 3000 series as that is right at the top of its range.
bluwtr49
Green Valley, AZ
Posted: 03/06/12 05:44pm Link  |  Print  |  Notify Moderator
Wonder why they don't use a 4000 series Allsion??
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
B's Bunch
Posted: 03/06/12 05:52pm Link  |  Print  |  Notify Moderator
so I am getting more hp and tourque with less weight. The block is the same as far as oil filters. Air should last a while as it is new. I am picky on oil changes Thanks Larry
steveownby
Cosby, TN
Posted: 03/06/12 06:10pm Link  |  Print  |  Notify Moderator
I'm sure the 4000 costs quite a bit more than the 3000 and there is higher maintenance cost as the 4000 holds 10 gals of Transynd at around $35/gal. The 4000 also weights almost double the 3000. If the 3000 will handle the hp & torque it's certainly the way to go.
wilpower
Posted: 03/07/12 06:41am Link  |  Print  |  Notify Moderator
B's Bunch wrote:
so I am getting more hp and tourque..............
I believe the torque stays the same, 1250 ft/pounds.
Wil & Cyndi & Einstein (African Gray)
