RV.Net Open Roads Forum: Truck Campers: awning question
 > awning question
SJR
Philadelphia, PA
Posted: 03/06/12 04:46pm Link  |  Print  |  Notify Moderator
I have a popup camper so I am looking at the freedom wall mount awning. The smallest one they have to 8', still not sure if this is the size of the enclosure or the size of the fabric. Either way the legs of the awning will be wider then the base of the camper. The awning comes with 2 brackets that are connected to the bottom of the camper to support the legs, but one leg will extend past the base. Does anyone have this awning? Do you just use one leg in a carport position? Are the legs long enough to reach the ground? I ask if they are long enough because I have a Fiami awning on the rear and those legs don't even come close to use in the carport position.
Stephan
2010 Dodge 2500 Crew Cab
2003 Northstar TC800EC
2003 Jayco Kiwi 21C
Equalizer Hitch
ISBRAM
Denver, Colorado
Posted: 03/06/12 05:12pm Link  |  Print  |  Notify Moderator
This is a 10' Carefree awning on the side of my Hallmark. Both legs are made to set on the ground.
99' Ram 2500 QC 4x4 Cummins. F&R Roadmaster Anti Sway Bars, Air lift 5000's, Stable Load's, Bilstein's
11' Hallmark Cuchara XL 9.5
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
SJR
Philadelphia, PA
Posted: 03/06/12 05:30pm Link  |  Print  |  Notify Moderator
I want to mount mine on the upper portion of the roof. Are you legs fully extended?
ISBRAM
Denver, Colorado
Posted: 03/06/12 06:27pm Link  |  Print  |  Notify Moderator
No the legs on mine are not fully extended, I think the legs are about 6 feet long. On my camper the awning is over 7 1/2 feet off the ground as mounted, why would you want it any higher?
SJR
Philadelphia, PA
Posted: 03/06/12 07:36pm Link  |  Print  |  Notify Moderator
I don't have room to mount it where you have yours, my window would be in the way. I would have to mount it above the canvas.
mkirsch
Rochester, NY
Posted: 03/07/12 11:01am Link  |  Print  |  Notify Moderator
Be careful about that. Your roof lift mechanism might not be up to the task of supporting an awning that's being blown/rained on.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
JimBollman
Upstate NY
Posted: 03/07/12 06:55pm Link  |  Print  |  Notify Moderator
We have been using our Shademaker Supreme 8' Bag Awning for 4 years. Don't use it all the time because we tend not to stay more than one day in any one place so don't put it up unless we are staying longer or need it for the short stay. No problem normally with the roof supporting it, we have went through some pretty high winds and the only problem is it can be noise. The flapping noise kind of gets directed up and in the window. We do lower it and add extra straps when there is wind forecasted. We normally get by with just the stakes through the loops on the bottom of the legs. Depending on our setup or how bad the wind is we either put extra stakes in the ground or use the chains on the side of the truck to add 1" straps for extra wind security.
We put awning rails on both sides of the camper so we can setup either way. Because we have seen bag awnings get moldy when left on the side of the camper and leak some water into the bag, we remove it and store it inside the camper while on the road. I mounted a couple of ball bungies on the ceiling along the side and tie it to the ceiling when we are setup and don't want the awning on. The same ball bungies lopp over the lift pipes when the top is down and holds the bag to the side so it doesn't slide around, one end up in the bed area the other on top of the back cabinet.
Jim...
 > awning question
