RV.Net Open Roads Forum: General RVing Issues: laws
silverthunderroad05
Seneca, SC, USA
Posted: 03/06/12 05:25pm Link  |  Print  |  Notify Moderator
has anyone heard of it being a law that if your weight of truck and camper exceed 10000 pounds you have to have a usdot sticker..any info would be helpful..
2005 Dodge, 24 Valve, Turbo Diesel Cummins
2009 Copper Canyon Fifth Wheel, Reese Slider Hitch, Prodigy Brake Control
Wills250psd
walnutcove NC
Posted: 03/06/12 05:29pm Link  |  Print  |  Notify Moderator
in NC recreational vehicles are exempt, I have a good friend that is a DMV officer
sch911
Rochester Hills, MI
Posted: 03/06/12 05:30pm Link  |  Print  |  Notify Moderator
Yes there is such a DOT law. But it's only for commercial vehicles, not for RV's. When we do trailer tow testing for any vehicle that has a GCWR over 10K we must be DOT compliant. So even a little ole Jeep Grand Cherokee trailer tow test requires inspections, log books, etc....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
KenandPamfromMI
Michigan
As far as I know, that is for commercial vehicles. I have several company vans/trucks...one of which is a cube over that weight....got hit with a ticket 2 years ago for no DOT numbers....Just to be clear...commercial meaning that if the TOW vehicle has advertising on it...you will be checked, even pulling a TT.
K Charles
Connecticut
Posted: 03/06/12 05:48pm Link  |  Print  |  Notify Moderator
If you don't have commercial plates DOT doesn't have anything to do with an RV
silverthunderroad05
Seneca, SC, USA
Posted: 03/06/12 05:57pm Link  |  Print  |  Notify Moderator
well i was told about it from a man that has a cattle farm and he said he had to get it.....im thinking he did because of making money and his farm is a business
silverthunderroad05
Seneca, SC, USA
Posted: 03/06/12 06:27pm Link  |  Print  |  Notify Moderator
thanks the info was helpful..
Swanny59
Lemoore, CA
Posted: 03/06/12 06:31pm Link  |  Print  |  Notify Moderator
State of CA limits towing a travel trailer to a GVWR of 10,000 lbs and a 5th wheel is limited to a GVWR of 15,000 lbs with a Basic class C license when towing is not for compensation. Trailers and 5th wheels exceeding the above mentioned GVWR's require a Noncommercial Class A License. Also A driver must have a fifth-wheel recreational trailer endorsement added to his/her Class C driver license to pull a fifth-wheel recreational trailer over 10,000 lbs., but not over 15,000 lbs. GVWR, which is not used for hire. This endorsement is not required if the driver has a commercial or noncommercial Class A driver license.
Ray & Addie
Lemoore, CA
2003 Dodge Ram 3500
2011 Sundance 3300QS
skipnchar
Topeka or somewhere else
Posted: 03/06/12 06:43pm Link  |  Print  |  Notify Moderator
State governments will be the governing agency for non commercial vehicles.
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 03/06/12 08:05pm Link  |  Print  |  Notify Moderator
Nope, DOT requirements are strictly commercial, privately operated RVs are exempt. Depending on the state and weight you may need a different class of license instead of a normal operators license.
BTW we weigh 38,000 lbs, no DOT ID of any kind and we do not stop at scales.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
