pipeline40
Nebraska
Ok just got a 2012 chevy silverado 2500 HD with 6.0 if I understand correctly it will tow 9500# Does that sound correct?
crickeydog
Marietta, Ga.
Congrat's on yer new pull dog. Ya got good taste in trucks!! What did the 2012 GMC tow guide say when factoring yer truck, engine, & axle ratio?
Happy camping!!! See y'all down the road!!!
USAF RETIRED. "EITHER LEAD, FOLLOW, OR GET OUTTA THE WAY"!
PULL DOGS:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT "THE SILVER FOX" PRIMARY
2000 DODGE 3500 QUAD CAB DRW CTD LARAMIE "THE ROAD TRAIN LOCOMOTIVE" BACK-UP
2004 HOLIDAY RAMBLER PRES. 30 SCD 5'ER
pipeline40
Nebraska
ok forgot to add 3.73 rear axle. ext cab standard box.
skipnchar
Topeka or somewhere else
Sounds like it COULD be about the right tow rating but to get the definitive answer to what your tow rating is I'd suggest you spend some time reading your owners manual. It should give you exactly what your truck is rated to tow (probably under the warranty information section). I would be a little surprised if it doesn't have a higher rating than that though. Most half tones tow more than that these days.
Good luck and congratulations on the truck / Skip
Coyotecprs
chicago
Your GVWR is 9500Lb. The GCWR is 16000lb and the truck weighs 6300lb if its a 4x4 or 6000lb if its a 4x2. So you are talking about 9700 or 10000lb minus the weight of passenger and gear in the truck in hitch. I would say limit your GVWR of the trailer to about 9000lbs or less.
2005 Dodge Ram 2500, 5.7 Hemi
2007 Jayco Jay Flight 30.5 BHS
therink
Rochester
That sounds about right. The tow rating jumps to 13k+ with the 4:10 axle gasser.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
fla-gypsy
North Florida
Sounds like it would tow that handily
Mitchellg
St.Louis
I tow a 10k lb 5th wheel with no problems. 2011 2500hd, CC, 4x4, 6.0, 3.73s, 20" wheels.
I'm pretty sure the manual says 13000lbs if it's a 5th, 10k if a it's a trailer. The manual for the 2011 is here: http://www.silveradosierra.com/download/chevrolet/silverado/owners_manual/2011_chevrolet_silverado_owners.pdf
tatest
Oklahoma Green Country
That's in the right ball park. Chevy's 2012 trailering guide shows 9600 to 10200 pounds maximum trailer weight for a 2500HD 6.0 with 3.73 axle, which gets a 16,000 pound GCWR (another 4500 pounds for the 4.10 axle).
9800 maximum trailer weight for your box/cab combination. Subject to reduction by what is loaded in the truck, and sometimes installed equipment.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
allen8106
Burrton. KS
therink wrote: That sounds about right. The tow rating jumps to 13k+ with the 4:10 axle gasser.
Looks about right, I would ssay.
2010 Eagle Super Lite 315RLDS
2009 GMC Sierra 2500HD 6.0L
1983 DW (love of my life)
2010 Pit Bull Terrier (Jake)
2010 Camping Nights 45
2011 Camping Nights 75
2012 Camping Nights 127
2013 Camping Nights 12
