RV.Net Open Roads Forum: Fifth-Wheels: lippert level up system
 > lippert level up system
Page of 12
LostinAZ
At Home
Posted: 06/18/12 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
buc1980 wrote:
I just install the level-up in Indiana and so far the system work OK.I notice that the trailer ,after it tell me that is level,is 1/4 off .I don't know if the sensor is install a litle off or what.
I'd like to understand this better. 1/4 off???
Lantley
Ellicott City, Maryland
Posted: 06/19/12 04:06am Link  |  Quote  |  Print  |  Notify Moderator
There is a procedure to zero or set the level point for the system.
The poster simply needs to set the level point for their system.
It is not a major problem or a problem at all
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
kakampers
Fulltimer
Posted: 06/19/12 08:10am Link  |  Quote  |  Print  |  Notify Moderator
cKarlGo wrote:
blkdodge wrote:
cherry
I tried the up arrow and even watched the video on my laptop while I was trying to figure it out. Lippert rep. told me if they put all the info on the CD or manuel he would be out of a job. Mine is in storage so I cant check for a while either.
He'll be without a job far more quickly if people stop buying the product because it doesn't work.
The system DOES work and quite well...have had it for three years, with the fully automatic brain installed a year ago...not one problem.
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
richfaa
Ohio
Posted: 06/19/12 08:44am Link  |  Quote  |  Print  |  Notify Moderator
As with any complex electronic system it has to be set up properly to function properly. Ours worked perfectly out of the factory.
The digital readout will give a " out of level" reading front to back and side to side during the level up procedure. It would be possible to not be able to get level IF you are on ground that is un-level enough to exceed the capabilities of the system. We were at a site that was sloped enough side to side that the entire left side of the RV was lifted off the ground to get a proper level. I did not like that and had to use a board on that side. The legs only extend so far.
One has to read the manuals carefully, Understand the system operation and a little practice. We spent maybe a hour in our driveway using the system and testing its capabilities.
It works exactly as advertised once you understand how it works.
* This post was edited 06/19/12 08:52am by richfaa *
cKarlGo
Alexandria, VA
Posted: 06/19/12 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
kakampers wrote:
cKarlGo wrote:
blkdodge wrote:
cherry
I was not making reference to the quality of the system, but the ridiculousness of the technicians comment. If you cannot get a system to work because of poor documentation, then the system is just as broken as if it had a mechanical failure.
k.
2012 Montana 3402 (Regretfully purchased from Camping World. Buyer beware!)
2011 Chevy 3500
2007 Black Lab/Pitt Bull mix named Harley
Cummins12V98
on the road
Posted: 06/19/12 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have it on my Mobile Suites now. If I were to order a new MS I would not order the auto level. I am very happy with mine as it is. I adjusted the RV so all 4 corners of the bottom side of the frame were parfectly level with a Hilti lazer level. Then I applied a surface mount level on the front right side under the overhang on drivers side and one next to the level controll access box, I used the Rite Stuff gasket maker for a solid bond.
I know how much blocking to put under what side based on front level.
Un hitch set level front to back, lower back hydraulic stabilizers so they raise rear slightly then lower front hydraulic landing gear to re level.
My landing gear and rear stabilizers are tipped out at the bottom 5 degrees and are guite stable.
Bottom line I know my RV is perfectly level when I am done and It may take me 5 minutes longer to set up but I saved a lot of extra money on something that a lot of people have trouble with.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
kakampers
Fulltimer
Posted: 06/19/12 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
I really don't feel "a lot" of people have problems with Level-Up...there seems to be a handful on this forum who have just not learned how to use it properly. Gives a skewed picture of a very good product...JMHO.
Cummins12V98
on the road
Posted: 06/19/12 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Most people don't have the level up on this forum.
Go to Mobile Suites forum and there are several who have had to go back to the factory or dealer and still are not right.
My point is I dont feel the need to push one button and have it level. I understand some can't tell when something is out of level or they use those useless levels with the ball bearing. So for them this may be the way to go.
I hope you the best of luck with yours. I know I will never have any of the problems with one because I can make mine have same end result with just a bit more work and a whole lot less money.
Sealyn
Northern California
Posted: 06/19/12 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
I can make mine level with blocks etc. also, but I prefer to push one button and let technology do it for me. If there is some problem with the system, I can always go back to my cave man ways.
Lantley
Posted: 06/19/12 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins I understand being stuck in your ways and not being willing to accept change and technology. Level up system are really not that complex. Once upon a time many thought slide outs were too complex and just something to break and fail.
Auto leveling systems are the wave of the future, there is nothing fun or rewarding to manually leveling a RV trailer. The future system will only get better.
Page of 12
