RV.Net Open Roads Forum: Class C Motorhomes: Damaged RV
 > Damaged RV
rfaivre
Bend, OR.
Posted: 03/07/12 12:08am Link  |  Print  |  Notify Moderator
I purchased a new 2008 Four Winds 31ft class c, and three years later I found a very serious leak inside the overhang. According to the tech's who repaired it, it was a mistake that the company made by not properly chaulking the edge of the roof to the exterior panel. Therefore the insurance company would not cover the damage. I wrote several times to the company asking for compansation and I was told that since the waranity ran out, they can not be held responsibe for the damage and the cost of repairs. In fact, my second letter which I mailed in October to the CEO, registered mail, has not responed back yet. It cost me $3,000 to repair the damage. My question to anyone, what would your next move be to resolve this issue? Any suggestions would be appreciated.
Thank YOu
fordsooperdooty
Posted: 03/07/12 12:29am Link  |  Print  |  Notify Moderator
They certainly are not going to say..."Oh darn, you're right..it's our fault!"
In the case of a RV 3 years out of warranty RV, Thor will quote you "that it is the owners responsibility to perform all required maintenance and inspections".
It even states this in the owners manuals. Thor/Four Winds RV assumes no responsibility after the warranty period, or even during the warranty period for something they will call "owner neglect". Sorry!
pulsar
Lewisville, NC
Posted: 03/07/12 02:26am Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
ksg5000
Oregon
Posted: 03/07/12 03:43am Link  |  Print  |  Notify Moderator
No offense intended but all RV's are prone to roof leaks and Class C's are notorious for leaks in the overhead cab area - leaks due to failure to maintain caulking are rarely (if ever) covered. Now that your RV isn't leaking make sure you closely inspect the roof at least twice a year and caulk as necessary - many have sealed the edges of their roofs with a product called Eternabond (lots of threads on that subject)
Kevin
Wills250psd
walnutcove NC
Posted: 03/07/12 05:26am Link  |  Print  |  Notify Moderator
Sorry, but I think you are out of luck!
Turner, P
South Carolina
I had a similar problem with our 2004 Fourwinds. Luckily, we caught it early and the repair was less than $500. The seal between the cabover and van top was installed badly. So it really only was a problem when driving in the rain. Looking back, it would have won some $$ on America's Funniest Home Video when the trapped water came rolling out on our heads.
Paul T
dqdick
Council Grove, KS
Posted: 03/07/12 07:48am Link  |  Print  |  Notify Moderator
Good Sam has an area where you can ask them for help and they will confront the company for you. Frequently, knowing the result could end up in the magazine, the companies respond. Doesn't cost much to try it and that's probably your last resort.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
NewsW
US
Posted: 03/07/12 06:08am Link  |  Print  |  Notify Moderator
Overhang roof leaks in Class Cs are best addressed with a one piece, fiberglass molded "nose".
Can also build one out of sheet metal / aluminum as is done in commercial trucks.
RV grade noses, with the joints, etc. are no-nos... and serious trouble spots if maintenance is not done regularly and properly.
mikeleblanc413
Sour Lake, Texas
Posted: 03/07/12 05:35am Link  |  Print  |  Notify Moderator
I'm with ksg5000...what a wonderful opportunity to learn the value of preventive maintenance...we had a smiliar leakage less than 30 days after buying our new to us Class C...I learned a lot about finding leaks, caulking, how others had addressed this issue, and most especially the value of this forum. Money can be replaced. Enjoy the motor home!
Mike LeBlanc, "The Digital Guy"
Professional Photographer, Retired Art Educator
Sour Lake, Texas
"Digital Guy"
Facebook
Flicker
garysol
Avon Ohio
Posted: 03/07/12 05:43am Link  |  Print  |  Notify Moderator
I had a Keystone Sprinter that we had to total out due to water intrusion that was due to a manufacturing flaw. I guess in the end it was my responsibility for not seeing that they had forgotten to use any sealant around a corner cap but since there was no old sealant there to begin with there was no old sealant to fix. It was an expensive lesson. I did contact Keystone and there response "no warranty"
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
 > Damaged RV
