RV.Net Open Roads Forum: Adding a 2nd Ac where should i put it?
 > Adding a 2nd Ac where should i put it?
Cajunco
colorado
Posted: 03/07/12 07:33am Link  |  Print  |  Notify Moderator
I would like to get some opinion's on where i should add my 2nd AC..
i have 2 vents that are free one in the hall near bathroom door and the other in bedroom.. also have a Fan-Tastic Ceiling Fan/Vent by the stove/dinette booth.. should i remove the fan tastic fan and put it in the hall and add the AC in the Kitchen so i can get the most ac in the living room? (thats where we will be in the hottest part of the day) or should i put the AC in the hall? i really dont wanna put it in the bedroom. (its such a small area)
Thanks for your Opinion!
J
1988 33ft Allegro Tiffin
chuggs
Posted: 03/07/12 07:37am Link  |  Print  |  Notify Moderator
Survey the roof... The larger footprint of the a/c unit might preclude placement in certain places due to inteference with vents, antennas, etc...
The one closest to the wall that is used to route wiring...might make it easier to fish power up to the unit.
WyoTraveler
Northwest, Wyoming
Posted: 03/07/12 07:38am Link  |  Print  |  Notify Moderator
My 5Ver had a vent in the hallway that was labeled for additional air conditioner on a very small label. I was all wired once the vent was removed.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
Cajunco
colorado
Posted: 03/07/12 07:53am Link  |  Print  |  Notify Moderator
I wonder if mine is already wired for AC in the hall..
my RV is 1988 ..
wny_pat
Western NYS
Posted: 03/07/12 07:54am Link  |  Print  |  Notify Moderator
Just a thought! Your current AC is in the living area? We usually run the living room AC at night when we are in the bedroom and the bedroom AC during the day when we are in the living room. This is due to the noise from the AC. Two ACs running in the living room would drive me out of the motorhome!!! Maybe your current AC is tired and ready for replacement!!!
Cajunco
colorado
Posted: 03/07/12 07:59am Link  |  Print  |  Notify Moderator
Yes the AC i have now is in the Living room.. it works great .. i just love to freeze lol i will only run both at the same time if its really hot.. i live in Colorado so we do get a few weeks of 100 degrees
enblethen
Moses Lake, WA
Posted: 03/07/12 08:01am Link  |  Print  |  Notify Moderator
I would put the AC in the bedroom. let it cool down and then shut it off while sleeping letting the front cool the rig.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
joelc
Milford, PA
Posted: 03/07/12 08:05am Link  |  Print  |  Notify Moderator
Going back always. One of the openings is probable pre-wired for an A/C unit. That is where you would put it. If possible, living room and bedroom. Keep the fantastic fan where you can get some nice flow-through on those days that don't require a/c, but are cool enough to keep the RV comfortable. Mine is LR/BR and fan near kitchen area.
Mr.Mark
California/Tennessee
Posted: 03/07/12 08:11am Link  |  Print  |  Notify Moderator
Also, keep in mind that if your '88 motorhome is 30 amp, you can probably only run one air at a time.
And, I also vote for the bedroom for the new location just for balance.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
Cajunco
colorado
Posted: 03/07/12 08:20am Link  |  Print  |  Notify Moderator
MM.
I have Seen lots of guys on here say they have 2 AC's on 30amps.. but if i have to i will change to 50amp.
The only thing i will have running with both AC's are on is the TV.
I will give it a try on 30amps in hopes that will work for both ac's ..
