RV.Net Open Roads Forum: Real world feed back: 245/75/16 VS 265/75/16
Search only in Tow Vehicles
 > Real world feed back : 245/75/16 VS 265/75/16
CND SuperCrew
SK, Canada
Posted: 03/07/12 10:14am Link  |  Quote  |  Print  |  Notify Moderator
The truck is going to need some new shoes come fall. I'm a regular member on other diesel sites but looking for towing feed back. This is what I know. Gearing is 3.73, going up the one tire size would equate to ~ 3.59
Thanks
Ron, Lori and Autumn
TV 2012 F150 loaded XLT EB SuperCrew 7700GVWR Maxtow 6.5'
TT 2008 Jayflight G2 23FB/ Equal-i-zer WD
2013 Colorado bound
2012- 4000km, 28 nights for the season
2011- OR & CA done, 6800km in 3 weeks
6.7 tow rig
kentucky
Posted: 03/07/12 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I did that on my F150 I had years ago. I went from 255/70/17 to 295/70/17. I could notice a little difference and that was a bigger jump than you are talking about. I personally like the way bigger tires look and the small hit in power I took was minimal. I dont think you would ever notice on your diesel. I know I will be going up two sizes when is time to change them on my diesel
2012 Dodge Ram 2500 Cummins 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
2003silverado
Michigan
Posted: 03/07/12 11:33am Link  |  Quote  |  Print  |  Notify Moderator
If we are talking about your truck and trailer in your profile, you will be absolutely fine. Where people should avoid getting a larger diameter tire is when they are at the upper end of their TV's tow rating...Which it looks like you are nowhere near. You will need to get your speedometer re-calibrated.
Some people don't recommend putting 265s on the stock rims, but MANY people do it and seem to be fine. I wouldn't recommend going any larger than 265 on the stock rims.
* This post was edited 03/07/12 01:08pm by 2003silverado *
CKNEK
White Rock, B.C.
Posted: 03/07/12 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
I went to 265s on my GM and noticed absolutely no difference in power or mileage. They did make the speedo accurate when compared to the GPS.
07 GMC CCSB Duramax with a few goodies.
BenK
SF BayArea
Posted: 03/07/12 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
245's are fine for general usage, but if pushing the limits, the of course
going bigger is better (in most cases)
I've had 4 or 5 sets of 265's after wearing out the OEM 245's that came
with my Sub (see sig)
-Ben Picture of my rig
Sandia Man
Rio Rancho, NM
Posted: 03/07/12 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Did the exact same thing on our TV and couldn't tell the difference either. The added capacity and the improved looks made it a no-brainer IMO.
CND SuperCrew
SK, Canada
Posted: 07/06/12 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
So I've narrowed down my choices, Toyo Open Country AT & Hankook Dynapro ATM, thoughts feedback...Thx
Toyo
Hankook
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/06/12 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
To properly run 265's, you should also swap the wheels to the wider, higher weight rated 16x7 factory stock wheels from the 3500SRW trucks. They are a direct-fit for your 2500 truck and will keep your new tires and wheels properly matched for wheel/tire width, as well as wheel/tire load weight capacity.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
carringb
Corvallis, OR
Posted: 07/06/12 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
x2.
Running 265s on narrower wheels will diminish handling because the sidewalls will flex more.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
North River
On the water
Posted: 07/06/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I've ran the Toyos and am currently running the Hankooks. I really like them both. I went with the Hankooks this time because they were less money. Both brands handle and wear well,and work good on and off road. If you can't decide,flip a coin. You'll like either.
