goshe
Denver
Being a lawn sprinkler man most of my life, I have found a very simple way to flush my holding tank. For about $7 and a trip to your local hardware store you can pick up a Rain Bird stream rotary nozzle 17'-24' and a couple of fittings to go onto the end of a hose. The rotating streams do a good job of cleaning the inside of the tank.
2007 Duramax, 2009 Hallmark Guanella, 2013 Cougar 28SGS
NRALIFR
Truck Camping Out West
Looks interesting. How do you do it? Shove the hose down through the toilet, or up through the dump valve?
I wonder if I could put one of those on the end of my rinse wand that I use down the toilet?
2001 Lance 1121 on a 2010 F450
Ranger Smith
Wherever the rig is parked
mayo30 wrote: goshe wrote: NRALIFR wrote: Looks interesting. How do you do it? Shove the hose down through the toilet, or up through the dump valve?
I put the hose in the dump valve opening, but it's a straight shot for me.
I don't know why you couldn't access the tank through the toilet with a flexible garden hose or wand.
It's nice to have the nozzle rotate in the tank as you pull it out. I think it does a lot better job.
So if I understand this correctly you push this up through the opening that you normally hook up your drain hose,turn it on and rinse away??
RIGHT . . . NOT FOR ME . . . THINK ABOUT IT
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
Ka Ron
Kelowna
That is an excellent idea..
Join Us For A Trip Down The RV Highway
mayo30
Up here in the cold,cold north.
goshe
Denver
tvman44
Southwest Louisiana
The gray tank for the kitchen can smell as bad as the black tank or worse. First I try keep food particles out as much as possible with fine stainless steel mesh screens we got at the dollar store. Occasionally I put a little bleach or pine oil down the drain to kill odors. I think the sprayer idea of yours inserted up the drain line from the outside would be a good thing after draining the tank first and I may look for one and use the garden hose at home to do that.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
goshe
Denver
Yep. The nozzle doesn't put out much water but you still need to watch where you stand.
goshe
Denver
Ranger Smith wrote: mayo30 wrote: goshe wrote: NRALIFR wrote: Looks interesting. How do you do it? Shove the hose down through the toilet, or up through the dump valve?
RVin's a dirty job. Just don't use your fresh water hose.
JimK-NY
fulltimer
I had a very nasty experience with my gray water tank. The tank had not been used or flushed for weeks and the odor grew to unbearable levels. Now I am careful with my tank. First I keep food particles out as much as feasible with the use of fine mesh stainless steel screens. These are available at Camping World and other suppliers. Next I periodically add a quarter cup or so of bleach to the tank. I drive around for a day or so and then flush the tank. I have not tried to stick some sort of sprayer up the drain. Considering the 90 degree angle, I doubt that would do much. Instead I do think very highly of the power of a little bleach.
