RV.Net Open Roads Forum: Fifth-Wheels: Wireless remote for lift/lower 5th wheel
 > Wireless remote for lift/lower 5th wheel
83trekker
calgary,ab,canada
Posted: 03/08/12 02:47pm Link  |  Print  |  Notify Moderator
Mile High wrote:
Curious what kind of remote you got? It can make a difference how you wire it.
Mine had a solenoid so I just went straight to the same spades the switch connects to with an up relay and a down relay. Be careful that if your remote is a "momentary up - momentary down" on the same button that there is a delay before it switches. Otherwise if you walk out of range or let up slightly on the button it will instantly reverse - and it's a little hard on the gear and motor.
I did buy another solenoid and added it to my slides so I could remote control them as well, but I don't remember where I got it. Somewhere on-line.
This is a 2 button remote. Its for a Tracker winch bought from Princess auto here in Canada.
ExRocketScientist
Laurel, MD
Posted: 03/08/12 04:25pm Link  |  Print  |  Notify Moderator
83trekker wrote:
I am having trouble finding a solenoid with 7 post like the one in my diagarm, or could the both postives go on one post, both negatvies on one post. and a postive go to the middle of the toglle switch and ground out each side of the switch?
Looked at your diagram. That is a solenoid made for reversing a DC motor. You need all 7 terminals wired as shown. It is made to work with a single pole double throw switch. Your remote then just hooks into the various terminals on the solenoid.
So who has a trailer that came with a solenoid? Once we find somebody with one, we can get the information off of it and track one down.
ERS
bpounds
Senile, er I mean
Posted: 03/08/12 04:52pm Link  |  Print  |  Notify Moderator
Wouldn't it be easier to just get the product designed for this application.
Landing Gear Remote Control
and cheaper yet,
Same thing from Adventurerv
* This post was edited 03/08/12 05:04pm by bpounds *
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
bstark
Ontario, Canada
Posted: 03/08/12 05:47pm Link  |  Print  |  Notify Moderator
The solenoid is required to control and direct the very high amperage required to feed through those 6 guage wires.
Any RV jack motors I've looked at had 12 guage at the largest so I'd be surprised if you'd even need a solenoid for any of them.
I kinda think the multi-function rocker switches used on most trailers are capable of the amperage load without a solenoid.
Today is just the tomorrow you worried about yesterday!
83trekker
calgary,ab,canada
Posted: 03/08/12 09:33pm Link  |  Print  |  Notify Moderator
and cheaper yet,
Mine was 50 bucks on sale, those above are way to expensive. Be alright if i had slides to extend out.
Mile High
CO
Posted: 03/09/12 10:23am Link  |  Print  |  Notify Moderator
If you need the solenoid - just google up "reversing solenoid" and a batch will show up. Here is what you would be looking for and there is a wiring diagram. Your two button remote should work.
reversing solenoid
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
83trekker
calgary,ab,canada
Posted: 03/09/12 11:06am Link  |  Print  |  Notify Moderator
This is what i am thinking too, do i really need solenoid if my motor doesnt have one? i know for sure its not wired with 6 guage , maybe 12 gauge at most.
Mile High
CO
Posted: 03/09/12 11:59am Link  |  Print  |  Notify Moderator
Actually I had it backwards - my slides had the solenoid, but the landing gear did not. The landing gear went straight through the DPDT switch. I added the solenoid because my remote control relays were not designed to handle the 30A the landing gear motor was fused at.
83trekker
calgary,ab,canada
Posted: 03/09/12 12:27pm Link  |  Print  |  Notify Moderator
So maybe i will be alright then with out it? cant wait to get my trailer in.
For the toggle switch for our landing gears, is the switch usually when you press it to eaither side to raise or lower competing a ground our a postive?
Mile High
CO
Posted: 03/09/12 01:45pm Link  |  Print  |  Notify Moderator
I'm scratching back about 5 years when I did it, but I think it was all switched on the positive side. I remember the generator start threw me off because it actually switched ground.
