RV.Net Open Roads Forum: Beginning RVing: How long does your battery last?
 > How long does your battery last?
Roy&Lynne
Pacific Northwest
Posted: 03/09/12 06:53pm Link  |  Print  |  Notify Moderator
We also have a solar system and generator and have never had a battery issue. We run out of water and propane before we lose electricity. I think its an investment worth considering if you plan to do a lot or any dry camping. We live in Washington State where its gray most of the day.
Our Road Less Traveled
mlts22
Austin, Texas
Posted: 03/11/12 03:26am Link  |  Print  |  Notify Moderator
If one does any boondocking at all, I highly recommend going with multiple batteries. Some go with pairs of 6V deep cycle golf cart batteries. Others with 12 volt batteries in parallel, because if one has a fault, it can be unwired, while a 6V battery that dies will kill the pair.
I personally like AGM batteries, because they don't need water added, and don't vent when charged, so are safer all around. However, you can pick up a deep cycle RV battery for about $100 at an auto parts store.
I'd read up on posts, to see what people do, and also shop around.
Veebyes
Posted: 03/11/12 07:34am Link  |  Print  |  Notify Moderator
No matter the size or type of battery, amps used are amps used. It is like the size of your fuel tank.
The aim is to cram as many amps into the available battery space of the trailer. It matters little whether you do it with 6V in series or 12V in parallel. After you have done that how long they last is up to you & your understanding of what uses how much power. You need to do a bit of educating yourself on the differences in batterys. There are batterys designed for starting & batterys designed as 'house' batterys. There are 3 main types of batterys, all having advantages & disadvantages.
Walking up & buying the cheapest thing on the shelf will likely see you back at that shelf much sooner.
2007 Alpenlite 34RLR
Shadow Catcher
NW Ohio
Posted: 03/19/12 06:45pm Link  |  Print  |  Notify Moderator
As mentioned by some one else in passing, conservation use of LED's and in our case I use three speed computer case fans instead of a Fantastic Fan, about 1/10th the power draw. Care and feeding of a deep cycle battery and preventing its early demise by for instance not letting it go below 50% depth of discharge. This also means you need to monitor your battery, this can be as exact as A Victron or Trimetric batte4ry monitor or as simple and monitoring the battery voltage.
The best single source of information is www.batteryfaq.org
I have a single 150AH AGM 12V Lifeline battery and 320W solar
RoyB
King George, VA
Posted: 03/13/12 09:49am Link  |  Print  |  Notify Moderator
Deep Cycle batteries will last a long time if you use a smart-mode converter/charger unit and never ever let your batteries get below 10.5VDC charge state. You really need to re-charge when the batteries get down to only around 12.0VDC which is considered 50% drained.
My three GP24 deep cycle batteries are on their fifth year now and still going strong.
When camping in the woods off the power grid the rule of thumb is generally one battery one night. Of course if you watch what you are doing you can probably stretch this out a bit but generally for conversation purposes one battery one night would probably be a good rule to follow. There are several thing you can do to make camping off the power grid a great experience.
I found that not just "ONE THING" will do this for you as you have to look at the whole battery system as a whole to be successful at it. The idea being you can survive the one night off the battery system and then be able to re-charge the batteries in a short 2-3hours the next day by connecting your trailer shore power cable directly to a 2KW generator and run that for the 2-3 hour time period to re-charge your batteries. Then you are good for the next night etc....
Been doing this for three seasons now and we are very successful camping off the power grid. When we get setup at camp site off the power grid, we just run an 120VAC extension cord from the trailer to whatever we need power for sitting around the camp fire..
My Posts are IMHO based on my experiences - Words in CAPS does not mean I am shouting
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
mowermech
Billings, MT
Posted: 03/13/12 10:40am Link  |  Print  |  Notify Moderator
Years ago I bought a 1977 Pace Arrow 27 foot Class A.
Our first trip in it was to a back-country primitive area, where there were no hookups, and the altitude resulted in night time temps of less than 40 degrees. The coach battery was an 8D battery, one of the huge truck/industrial types.
With the thermostat set at 55 degrees, it went dead at 3 AM! I had to get up and start the engine to get enough power to start the generator. It was COLD in there!
In our current RV (see sig), with two Trojan T-105 batteries, we have gone 4 days with minimal generator run time, and no furnace use. No problems.
So, I guess MY battery lasts anywhere from less than overnight to 4 days or so...
It depends!
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC LWB, Cummins, Automatic, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs.
N3YMY
Brunswick, MD
Posted: 03/12/12 10:03am Link  |  Print  |  Notify Moderator
Golden_HVAC wrote:
Lights will use about 1 amp hour per hour, and furnace about 7 amp hours per hour.
With LED perhaps.
With fixtures with dual 921 bulbs, it's about 2.5Ah/fixture.
Same fixture with LED, about 0.2Ah.
Those values were actually measured.
What kind of lamps are you using that get 1Ah...?
Searching_Ut
Utah
Posted: 03/11/12 09:13am Link  |  Print  |  Notify Moderator
From what I've seen, parasitic draw varies quite a bit between different units. My Springdale TT draws somewhere between an amp and an amp and a half per hour just sitting there with the refridgerator on gas. If it has a door heater there isn't a switch for it, and it sounds like there is a fan that kicks in on hot days for the exhaust, but I haven't tried to get back there to see where it is. For us, we find we can generally go for a three day weekend on two group 24's without running the generator.
That said, more often than not I run my inverter generator for at least half an hour in the mornings so the DW can use the curling iron and hair dryer. Since I have to fire it up anyway, If we have the time and can leave it running an hour or more each day we get enough juice back in the batteries to keep us from having any issues.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
bryanl
Reno, NV
Posted: 03/11/12 10:46am Link  |  Print  |  Notify Moderator
and it is a very small fuel tank!
Lead acid batteries have about 12 usable watt hours per pound of battery. That means a group 24, which is typical in smaller RV's, has about 550 watt hours usable while a group 27 about 650 and a T105 about 725. Note that these ratings are for about a watt of power draw per pound of battery. Larger draws will reduce the available energy.
Figure maybe 10 watts for residual (alarms, control boards) so that's 240 watt hours per day. An incandescent bulb is about 15 watts, a typical RV fluorescent light is about 30 watts, The furnace is up to 100 watts.
The upshot is that a battery can go real quick if you aren't careful. Adding more or bigger batteries might help some but not so much in real terms.
Try to avoid letting your battery go below 12.2v as measured after a half hour or more of no significant charge or discharge if you want best battery life. Always keep it on a good maintenance charging system when not in use that will maintain a full charge and apply a sulfation inhibiting technique for best service.
Bryan
time2roll
Posted: 03/19/12 07:07pm Link  |  Print  |  Notify Moderator
One battery, one day. Maybe two if you conserve. Maybe 3 if you discharge it well beyond 50%. Maybe 5 days if you turn virtually nothing on.
I run with four batteries and 600w of solar now [emoticon]
675w Solar pictures back up
