RV.Net Open Roads Forum: Towing: moaning sway control
Search only in Towing
Open Roads Forum  >  Towing
 > moaning sway control
4runner roo
cape cod ma
Posted: 03/07/12 04:52pm Link  |  Print  |  Notify Moderator
I just got a new wdh with friction sway control .This thing makes a lot of moaning noises its a Reese pro series 1000 lb bars.My previous hitch was the same except 600lb bars but the only time it made noise was when it was wet .Is their some reason the new one would make so much noise.
badboy368
OHIO
Posted: 03/07/12 05:13pm Link  |  Print  |  Notify Moderator
a little bit of spray lubricant or grease. it may collect some dirt sometimes but its easy to clean off and re-apply.
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
allen8106
Burrton. KS
Posted: 03/07/12 05:14pm Link  |  Print  |  Notify Moderator
DO NOT spray anything on them. It will damage them. they always moan. Check your instructions.
2010 Eagle Super Lite 315RLDS
2009 GMC Sierra 2500HD 6.0L
1983 DW (love of my life)
2010 Pit Bull Terrier (Jake)
2010 Camping Nights 45
2011 Camping Nights 75
2012 Camping Nights 127
2013 Camping Nights 12
301TBS
Ontario, Canada
Posted: 03/07/12 05:27pm Link  |  Print  |  Notify Moderator
It is normal, as said. If u lube it, it will no longer be a "friction" sway control.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 03/07/12 05:28pm Link  |  Print  |  Notify Moderator
Oh no! never lubricate them! I agree! The purpose is for friction. The tighter the better. You can lubricate the little ball on the frame of the trailer and you can lubricate the little ball on the hitch, but never lubricate the slide bar itself. If your sway bar made no noise at all, I'd be worried. (It's not tight enough). But more likely, the ball on the hitch may need a good dose of grease too. You can test this out by simply driving a short distance with the sway bar on, make a few turns and see if you hear the groaning. Then remove them and make turns again. If the groaning is gone, it's definately the bar. It's perfectly OK the bars make noise.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
2112
Posted: 03/07/12 05:43pm Link  |  Print  |  Notify Moderator
Are you sure it's the friction plate? My trunnion bars moaned where they attach to the hitch until I greased them. Grease all contact points EXCEPT the plate itself and see if that helps. Are you sure you need the friction plate adjusted so tight?
2011 Ford F-150 EcoBoost SuperCab, Timbrens, PullRite SuperGlide 2700 15K
2013 KZ Durango 1500 2857
Terryallan
Foothills NC
Posted: 03/07/12 06:14pm Link  |  Print  |  Notify Moderator
The friction is adjusted at the factory. You will in all likely hood never need to adjust it more.
The Handel is NOT the adjustment. It is the On /Off switch. When the Handel is tightened all the way to the bolt stops, The bar is "On". Loosen it, and it's off. Lube it, and it's useless.
The adjustment, Is the bolt UNDER the Handel. Leave it alone. Until the pads begin to wear out.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
BarneyS
S.E. Lower Michigan
Posted: 03/07/12 06:42pm Link  |  Print  |  Notify Moderator
Good and correct advice by Terryallan!
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
eric james
Sioux Falls, SD
Posted: 03/07/12 07:39pm Link  |  Print  |  Notify Moderator
First, make sure it's the friction bar and not the trunion heads. Grease the sockets for the trunion heads.
If it still moans, it will quiet down with use.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
SWD
Land of Living Skies
Posted: 03/07/12 08:11pm Link  |  Print  |  Notify Moderator
And there again it may not. After 7 years of use mine are still noisy.
Put lube on them...you might as well throw them away.
