8iron
Canada
Vulcaneer wrote: ExRocketScientist wrote: Some have been bent between the spring and the wheel. How did they manage to do that?
If bent between the spring and the wheel, this is generally referred to as a bent spindle. Because the actual axle, very rarely bends in that area. Reasons for a bent spindle are hitting something hard with that wheel, while carrying a heavy load over that wheel. Could be a pothole. Could be hopping a curb while making a turn, then dropping off the curb. Could be by pinching the wheel up against a curb, or something while making a turn. This forces the bottom of the wheel towards the inside, and the lateral pressure causes the spindle to bend at it's mounting point.
And then off course, overloading the trailer and hauling over bumpy roads can fatigue the axle over time. This fatigue can occur at the spindle mounting, the center of the axle, or any other point. Then there are those (seriously uninformed) that position a jack in the center (or toward the center) of the axle to lift the trailer to change a tire.
Probably many other reasons too. But honestly I don't know of any manufacturer that intentionally under rates a trailers axles. And there is a label that shows cargo carrying capacity. But people will still overload the trailer, and feel the trailer axles are under rated, rather than accept blame for themselves.
I agree with most of what you are saying...In my case the TT was equiped with 3500# axles on a unit that had a UVW of 6,200#. The axles were at 90% of capacity before I put water, propane or any of my stuff in it!! The GVWR of the unit is 7800#. Our wet weight as we left the dealer lot was Cat scaled at 6800#. Once I started looking at other TT manufacturers, the majority seem to be doing the same thing. Yes, on paper the numbers work, and yes, you would subtract tongue weight from the total but when you are already so close to the limits then add the really poorly manufactured Lippert axles on a unit bouncing down the road, it is inevitable they bend.
2011 F250 Lariat FX4
2011 Sunset Trail Reserve 29ss
RCMAN46
NorthWest
I had a Lippert axle fail from a rough section of I40 between California line and Meteor Crater,Az. The spring perch which is on top of my axle collapsed into the axle tube. This happened on both sides of the rear axle. To those who do not think they can collapse an axle tube by jacking up their trailer with a bottle jack on the axle tube this is to me enough that it can happen. The axle was replaced under warranty but I had to spend 3 extra days at Meteor Crater campground waiting for the axle replacement. After the repair I checked my weights on a CAT scale in Flagstaff and I was only 4200 lbs on 5200 lb axles. The weights were only about 80 lbs difference from front to rear axle. I found the problem when I noticed the rear tires were wearing on the inside. After the repair I looked at the failed axle. I was shocked how light in weight the axle is and how thin the axle tube is.
ExRocketScientist
Laurel, MD
goducks10 wrote: 8iron wrote: ExRocketScientist wrote: For those of you who have bent an axle tube on a trailer, how did it happen?
Undersized axles of inferior quality (Lippert) = 2 bent axles.
Partialy agree. I have 2 Lippert axles that bent. Don't know why. But they are not undersized in my case. Each one has a 4400# rating. x2 =8800#. My TT weighs 72-7300# loaded. The place where I took them to get straightend mentioned that they were made with soft material. So ya the quality is inferior, but they are rated okay.
I thought only Dexter made a 4400 pound axle.
ERS
goducks10
Keizer OR
ExRocketScientist wrote: goducks10 wrote: 8iron wrote: ExRocketScientist wrote: For those of you who have bent an axle tube on a trailer, how did it happen?
They may but so does Lippert
Randu
South Central Michigan
Lipert bought out Dexter not too long back so the future is all Lipert axles. Randu
2004 GMC 2500HD 8.1 Big Block gas
2008 Mobile Suites 36TK3
mapguy
Puget Sound
Randu wrote: Lipert bought out Dexter not too long back so the future is all Lipert axles. Randu
So wrong.
Lippert purchased only the Chassis Division of Dexter. Dexter Axle is alive and well.
Lippert does not build the axles with their name -they are built by Axletek under contract.
ExRocketScientist
Laurel, MD
They bought out Dexter Chassis, not Dexter Axle. Two different companies.
up2nogood
Utah
Are you asking because of a bent axle you own, I did notice in one of your post that there were pictures of an axle being jacked up on the axle tube, I am assuming that was yours. I would probably find a better place to jack then that.
Randu
ExRocketScientist wrote: Randu wrote: Lipert bought out Dexter not too long back so the future is all Lipert axles. Randu
Thanks for educating me, I thought it was all one company due to what I was told by my brother in law that works at a RV dealer. (He must have been hanging around some of the salesman) Randu
chipper
Nampa,Id
Does everyone realize that the axle weight rating system is running on an honor system & no one is checking to see if they are all honest.
gene
