RV.Net Open Roads Forum: General RVing Issues: Which FloJet Macerator- Twist or Permanent
 > Which FloJet Macerator- Twist or Permanent
EricGT
PA
Posted: 03/08/12 06:52pm Link  |  Print  |  Notify Moderator
SCVJeff wrote:
EricGT wrote:
Wow...just did some additional searching on Macerator pumps.
There sure are a lot of experienced people that do NOT like them or have removed them and thrown them in the garbage.
The biggest complaint is what others have said, back up of sludge in the black tank.
Great...so now I am back to my dilemma of getting sewage to my clean out 75' away.
Do you have a water faucet or can you get a real water hose to it?
Yes= Get a good tank rinse system and use it
No= Then you have a problem
Yes on the hose.
Does the hookup for the hose to the black tank count?
2002 'The Rogue' by Mckenzie div of Monaco Coach
24' E450 chassis, V10, Class C, Single slide
BigRabbitMan
Dixon, CA
Posted: 03/09/12 08:59pm Link  |  Print  |  Notify Moderator
Yes on the hose.
No problem! You just dump with the macerator and when finished, put several inches of water into the tank. Then put in some of the bacteria that is made to be added to septic tanks. Your nearest hardware store should have it. That will provide the bacteria to eat up any materal left in the tank and will elimate any sludge buildup.
Don't make it a bigger issue than it is.
BigRabbitMan & DiamondGal
Diatomaceous Earth for health
76 FMC #1046, Gas Pusher W/Chrysler 440-I
Edelbrock MPI fuel injection, Allison 545
Toad: Red '87 4x4 Subaru Brat, '95 Honda Accord
DataStorm Satellite internet / I am here-click to see
EricGT
PA
Posted: 03/10/12 06:30am Link  |  Print  |  Notify Moderator
Thanks!
I'm going to an RV show today.
If I can get a twist off system for $250 and the 20' hose extensions for $50 each...I'm in.
Wherever I happen to park
Posted: 03/10/12 10:05am Link  |  Print  |  Notify Moderator
That is why I use a portable (one that twists on and off) when I have a normal run to the hole in the ground.. As i do here, I use the 3"
When it's a long way to the sewer.. Or Uphill, or some other "issue" I use the pump and haul away.
I used to have a friend who spoke of the law of requisite choice.
"You may live only so long as total choices is greater than fatal choices"
Though, in this case, I don't think there is a fatal choice.. Still. I believe choice is good. Thus, use one when you have to. Use 3" when you can. Best of both worlds.
