RV.Net Open Roads Forum: Class A Motorhomes: using biodiesel to increase lubrication
 > using biodiesel to increase lubrication
n4hwl
Murfreesboro,TN
Posted: 03/08/12 10:16am Link  |  Print  |  Notify Moderator
I have been reading to find which additives for diesel fuel are best to increase lubrication of pumps ect. I found this study http://www.dieselplace.com/forum/showthread.php?t=177728
and it seems that best thing to use to increase lubrication is biodiesel. In this study very little 100% biodiesel was added to regular diesel and it provided better lubrication than all the other additives tested. I do understand that biodiesel will definitely clean out the inside of the tank and fuel lines and stop up the fuel filter in short order. I would assume that after a few tanks full and probably several filters this problem would get better over time. Am I right? Has anyone any experience with biodiesel in their motorhome after running regular diesel for a long time. My motorhome has 50K miles on it. I have lost 2 injectors in the last 20K miles and was thinking about adding some sort of additive to the fuel to insure lubrication. If I used biodiesel I would probably start by adding a few gallons per tankful. Biodiesel is not that easy to find in my neck of the woods. I have not made up my mind yet on what to use but do know that the 15 ppm diesel we get now may or may not have enough lubricating properties. This all depending on the manufacturer putting enough lubricating additive in to replace the lubricating properties that were removed when the sulfur was taken out. Any constructive suggestions would be helpful..
Thanks
Ken
2004 QDH 40ft Phaeton, Blue Ox Tru-Center
Ham Call N4HWL, TS performance mp-8
rvrepairnut
bc
Posted: 03/08/12 10:51am Link  |  Print  |  Notify Moderator
I have never heard of anyone with the electronic Fuel injection(what u have) cummins having any problems with ULS diesel fuel?
The last thing iam going to be doing is expermenting with bio diesels in my 425HP ISL that i can tell U.It runs perfect on the ULS pump fuel.Just keep the filters in good shape
2oldman
Winchester WA
Posted: 03/08/12 10:53am Link  |  Print  |  Notify Moderator
bio-lube-additive posts
FormerBoater
South Florida
Posted: 03/08/12 11:04am Link  |  Print  |  Notify Moderator
Opti-Lube Summer Blend was one of the top performers in this study and it is inexpensive and easy to buy (sell direct on the web).
I have been using it for 3 years in my engine which was designed to run on Low Sulfur Diesel and have had no lift pump or other issues.
7 ounces per 150 gallon tank gives you the optimum performance so it is easy to add a sufficient amount when needed.
Dave
1998 American Eagle 40EVS
bob213
Fresno, CA
Posted: 03/08/12 11:18am Link  |  Print  |  Notify Moderator
bio diesel did come in first but I haven't found anywhere around here to get it. I think it was soy based also. I use OptiLube XPD at the minimum rate and as far as I know it works. There's really no way for me to know if it's doing what it's supposed to until something breaks (or it doesn't). Even if it's just a false sense of security, I'll continue to use it.
ScottG
Bothell Wa.
Posted: 03/08/12 11:38am Link  |  Print  |  Notify Moderator
Excessive levels of bio can have negative affects on your high pressure pump.
It's not likely that lack of lubrication is what damaged your injectors but instead, it's dirty fuel. The stock filters do not filter down to the level recommended by most FI companies (like Bosch). You would be better served by adding a 2 micron filter.
Also, do you know what kind of failure they had? If it was electrical and a code showed up then it had nothing to do with fuel at all.
Scott, Grace and Wesly
H0NDA eu2000i
J-Rooster
Port Orchard, Wa. / Lake Havasu City, Az.
Posted: 03/08/12 01:26pm Link  |  Print  |  Notify Moderator
I agree and I'm a big believer with the filters. I don't know anything about lubricating fuel pumps and, I drove diesels for 42 years and over 4 million millions and never lubricated one pump. How things have changed in the 2 years, since I retired!
frankdamp
Anacortes, or wherever we've gone.
Posted: 03/08/12 01:44pm Link  |  Print  |  Notify Moderator
Diesel fuel is oil! Why would it need added "lubricators" mixed in?Also, trying to mix a vegetable-based liquid into a petroleum-based one might not work. I doubt it would dissolve.
Frank Damp, DW - Eileen
Anacortes, WA
'02 Georgetown 325, F53, V-10, bought used in 2010 at 13,000 miles.
Dogs - 2 Labs again, both yellow males, both 9 yrs old and both adopted.
bluwtr49
Green Valley, AZ
Posted: 03/08/12 02:59pm Link  |  Print  |  Notify Moderator
Best check with the engine folks and find out it it rated for bio, and if so, what percentage. That age it might not be or limited to 5%.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
FormerBoater
South Florida
Posted: 03/08/12 03:30pm Link  |  Print  |  Notify Moderator
Old Low Sulfur Diesel was 500 ppm Sulfur max, today's ULSD is 15ppm Sulfur max. Sulfur provided much of the lubricating qualities of diesel fuel.
ULSD is a much "drier" fuel and has caused problems in older diesel fuel delivery systems. The primary failure point has been the lift pumps which need the lubrication from the fuel...the owner/operator does not lubricate anything as the fuel takes care of this.
The study referenced in this thread gives the results of an independent study and it is an interesting read.
Lift pumps are expensive!
