RV.Net Open Roads Forum: Tech Issues: Uni-Solar PVL Flexable Solar Pnanel Question
 > Uni-Solar PVL Flexable Solar Pnanel Question
cruz-in
Southern Maryland
Posted: 03/08/12 04:40pm Link  |  Print  |  Notify Moderator
Hi All,
Looking at the Uni-solar PVL line of solar panels. These are the felxable ones that are about 16 inches wide and (depending upon wattage) up to 17 feet long. My question is for anyone that has used these.
Did you just use the self adhesive on the panels and glue directly to the roof?
I ask because the instructions I downloaded show they panel being first mounted to a thin piece of sheet metal (via the self adhesive) and then the metal (with panel attached) mounted to the roof.
Thanks
2oldman
Winchester WA
Posted: 03/08/12 05:42pm Link  |  Print  |  Notify Moderator
A search of uni-solar on here turns up a lot of posts.
cruz-in
Southern Maryland
Posted: 03/08/12 05:54pm Link  |  Print  |  Notify Moderator
Thanks. I did the search a while ago and read virtually all the posts. I could not find any that were clear on how they were applied. A few references like "I stuck them on my roof". I started this thread hoping for a bit more detail.
hershey
Albuquerque,(fulltime) NM, USA
Posted: 03/08/12 06:48pm Link  |  Print  |  Notify Moderator
I installed one on a friends Chev Class B. It just glued down directly to the roof. Far as I know, Its still bonded and in use. That was two years ago.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
pianotuna
Regina, SK, Canada
Posted: 03/08/12 08:32pm Link  |  Print  |  Notify Moderator
Hi,
I believe Wanderman used self adhesive panels. He put them directly on the roof.
Personally, I'd put them on metal roofing panels, and then mount those on the RV.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
rexlion
Broken Arrow OK
Posted: 03/08/12 09:14pm Link  |  Print  |  Notify Moderator
If you thought you might want to remove the panels later without ruining them, attaching to a backer plate would be the way to go. Personally I'd just stick 'em right on the roof (if I had room!).
Mike & Sherry
2000 Mercury Mountaineer
2008 Toyota Highlander
2011 KZ Spree Escape E14RB
hershey
Posted: 03/08/12 09:43pm Link  |  Print  |  Notify Moderator
Just a thought; If you stick them to a sheet of metal so that they could be removed, wouldn't it be much more economical to just go ahead and buy the regular box type solar panels?
pianotuna
Regina, SK, Canada
Posted: 03/08/12 09:51pm Link  |  Print  |  Notify Moderator
Hi Hershey,
Yes, it would be cheaper--but the unisolars are pretty wonderful in the shade tolerance arena.
cruz-in
Southern Maryland
Posted: 03/09/12 06:05am Link  |  Print  |  Notify Moderator
I would like to put the 124 watt ones on my roof. However I only have 14.5 feet and they requiere 16.5 feet. The last 2 feet would be off horizontal as they round the back of the camper. With last foot being vertical on the back of the camper. I would end up with about 100 watts of the panel horizontal and the rest less than optimally placed. Still beats going to the smaller 64 watt panels...
cruz-in
Southern Maryland
Posted: 03/09/12 06:07am Link  |  Print  |  Notify Moderator
Wonder if mounting on metal panels first would improve performance by dissapating the heat better?
