I'm thinking it might be time (should have done this about 3 years ago) to purchase some type of RV storage to get it out of the weather.
I'm thinking about going with this one from Home Depot since I can charge it at no interest: Click here to see it.
It shows the dimensions of 14' wide x 38' long x 12' sides. I'm not 100% sure the 12' sides will work for me. I'm wondering if can create some type of foundation under it and anchor it to the ground after that. I would like to be able to have the slides out while it's in the carport.
You could pour a concrete footing on each side to raise it to the height you need but with slides on both sides, I would measure coach width with al slides out to see if it will fit. You might find a metal company that can custom make you one to your specs.
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
I will have to measure it when I get the RV tomorrow. I sent it out to get it washed and waxed. I hope it will work, otherwise I will have to find someone local to build me one.
What about the front of the RV? It will still be exposed to the sun if all I put up in this RV Carport. The position the RV is parked, the sun will rise in the front of the RV and set in the rear of it.
bccsrc,
Well, we were in the same boat last July. We'd just purchased our new to us '04 Itasca Horizon, full body paint, diesel pusher with the 330 CAT and, it is such a beautiful rig that I was not going to let it sit in the sun and all the rest of the elements if I had anything to do with it. So, the quest began. We'd researched all of what was available within our area.
Long story short, after considering almost shelling out $4500.00 for a 19'x45'x12' canvas clad cover, (and I was within seconds of writing the check) we decided to step back and see if that was the best move we could make. That price was for all the parts, and a company doing the install.
In the end, I purchased all the components from two different sources and did the work our self. Now, I will admit, ours is not as permanent as the one you're thinking about. In that, it's a cheaper gray tarp style with bungees. The total cost, up and standing as you see in the pictures, was $1400.00. I did it that way because in our area, it's questionable as to whether a "Permit" is needed or not. I'm sick and tired of government regulating me to death so, we took a chance and put up that style cover.
That way, if some county goon comes knocking and tells me to take it down, I can eat that cost and maybe get some of it back by selling it or whatever. But, if I shelled out as much as you're thinking of, which was almost the point, I'd be really P.Od.
My cover ended up being 18' wide, x 40' long and 12' sides. Well, when I walked across the street to look at it from my neighbors point of view, it looked a bit hideous. So, the wife and I "cut it down" to 11' sides. Way better.
Anyway, it's just some ideas for you to ponder. The cover, covers all the way down to the 6' fence on one side and is approximately 8' from the ground on the other side where the whole cover is very close to the house anyway. So, in all reality, the sun never touches the coach, no matter what season we're in. It looks way open but, again, it was primarily for protection from the sun.
Scott
Scott and Karla SDFD RETIRED
2011 White Honda CRV EX-L,4WD w/NAV Toad 2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
Was in the same quandry a few weeks ago.Decided to call Morton buildings.They are going to start construction around May 1.Building a 30'X 40' with two overhead doors. A little pricey but has a 3 year overall warranty and more on materials..Around here WIND is a real concern.This building is for mine and my sons R.V.s.Good news,we are splitting the cost.It is being built on his property and when I am done with it,the building is all his.
edited 03/10/12 06:19pm by T bone *
1999 Georgetown 325S,V-10 Ford.
2002 Ford Ranger Edge toad
carrying a 2001 Yamaha Warrior.
You might want to check with TNTcarports.net I have 2 of their ports and plan to have them install another one for our 5th wheel. I will be looking at one about 20' wide x 14' tall x 36' long.
Deep wedgewood blue '99 7.3L PSD F-350 Super Duty crew cab long bed dually or wedgewood blue '97 F-350 7.3L PSD crew cab longbed SRW, Member: Sunlineclub.com Rescue a retired Greyhound, greyt calm low maintenance traveling companions
I would not go less than 14 feet wide. I have a 16x38 and 13'6 center. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
I don't know what is available for your area, but I looked at http://www.rvcarportsdirect.com and they had a 12X41 12 high for
$2855.00 and I install it.
I contacted my local "Lark" outlet and I can get a 12 X 41 X 15 tall for $2027.65 installed. Lark sells nationwide I think.
http://larkbuildings.com/carports.php
