RV.Net Open Roads Forum: Class C Motorhomes: RV propane tank emptying ?
 > RV propane tank emptying ?
tourusa
miami
Posted: 03/08/12 05:43pm Link  |  Print  |  Notify Moderator
Hi Alll I've been having problems with the automatic lighter on my atwood and someone said when did you last empty your propane tank and get the air out ?
Can anyone tell me if this needs doing and step by step how to do it with my propane tank in my class C RV thanks
rvten
Crossville,TN
Posted: 03/08/12 05:53pm Link  |  Print  |  Notify Moderator
That's a new one.
Maybe a dirty regulator. Lower gas pressure.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
Ka Ron
Kelowna
Posted: 03/08/12 06:00pm Link  |  Print  |  Notify Moderator
I think what they may be talking about is....when your unit sits for awhile the propane will dissapate (sp) out of the line and when you try and light your appliances it takes a bit of time to get the air out of the line and the propane back up to the appliance.
One way to help is to light the burners on the stove first.
Join Us For A Trip Down The RV Highway
CloudDriver
New Jersey Shore
Posted: 03/08/12 06:06pm Link  |  Print  |  Notify Moderator
A propane tank is under high pressure. The only way to get air in would be to completely empty the tank and leave the valve open. Even if some air got in, it would come out with the propane gas and be gone in no time at all.
If your stove burners work normally, you don't have a problem with the propane itself.
2003 Winnebago Minnie 24F - Ford E-450
tourusa
miami
Posted: 03/08/12 06:57pm Link  |  Print  |  Notify Moderator
thanks Yes my Atwood has been acting up and someone said air in the tank ?
Dakzuki
Carnation, Wa, USA
Posted: 03/08/12 07:12pm Link  |  Print  |  Notify Moderator
I presume you mean your water heater?
Are you getting a good spark?
Have you tried manually lighting it?
Sometimes the jet can get clogged. It happened to me. I took the jet out and cleaned out a pile of rusty crud behind in on my Chinook. Worked great after that.
I was getting a weak flame that wouldn't heat the thermocouple enough to keep it running regularly. It got progressively worse until I couldn't keep it lit.
2011 Itasca Navion 24J
95 Chinook Premier
rehoppe
Denver & Nathrop Colo or somewhere else
Posted: 03/08/12 07:24pm Link  |  Print  |  Notify Moderator
Plus on on the HUNH?
Air in the line, not air in the tank. Plus one on light a stove burner first.
The Clean the jet is good too.
Maybe we should ask. Do the Frig and stove work well? If not maybe the regulator.
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
rehoppe
Posted: 03/08/12 07:27pm Link  |  Print  |  Notify Moderator
By the way, what are the symptoms?
tourusa
miami
Posted: 03/08/12 08:12pm Link  |  Print  |  Notify Moderator
Hi How do I take off the jet and clean...? is it the brass looking fitting with the pin hole can you take this off with a spanner without emptying the tank ?
I can manually start the atwood with a BBQ lighter and fridge stove work great, no spark new ignitor?
thanks all
hohenwald48
Hohenwald, TN
Posted: 03/08/12 09:01pm Link  |  Print  |  Notify Moderator
Brand new propane tanks that have never been filled do have air in them and do need to be purged of that air. However, once done it never needs to be done again. However, the lines from the regulator to the appliances can get air in them if they sit unused for extended periods of time.
I doubt if the "jet" needs to be cleaned. I have heard of insects or insect nests getting into the burner tube and causing a problem.
2008 Fleetwood Jamboree 25G
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
