LoneWolfWarrior
No where
Hey everyone,
Well, my rear driver's side hydraulic jack is not going down all the way for some reason. Any ideas about what's going on and how to fix it? It's a 2000 Fourwinds Hurricane.
Thanks!
LoneWolfWarrior
2000 Four Winds Hurricane 33SL
Ka Ron
Kelowna
Check the fluid level????
Join Us For A Trip Down The RV Highway
Mr.Mark
California/Tennessee
Lone, if it's hydraulic, you will have a hydraulic tank which uses automatic transmission fluid. Locate the tank and check the fluid. Your owners manual will tell you where it is located.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
LoneWolfWarrior
No where
How would I do that? And would that be the case if just one is not going down?
1995brave
San Antonio, TX
If you have the HWH jacks just go to www.hwh.com find your model and download the manual. There is a section on troubleshooting that should point you right to the problem.
dougrainer
Carrolton, Texas
If other jacks fully extend but not just 1, to rule out fluid level is simple. Activate ONLY the jack that does NOT fully extend. IF it does NOT fully extend it is NOT the fluid level. You need to figure out what brand and type system you have to get better answers
HWH
Powergear
LCI (Lippert)
LoneWolfWarrior
No where
Great thanks so much!!
TN Tarheel
East TN
My 2004 Hurricane is in the shop now to repair line to driver side rear jack. Have had problems off and on with it and as I was lying underneath waiting for oil to drain,I noticed slight dripping from connection at control box. Since I am old and stiff I decided to let someone younger and for flexible tackle it.
Yankee Clipper
Cairo, GA
Some contact info: HWH (800)321-3494
A couple of quick troubleshooting items: Look in your battery compartment, the usual place for the hydraulics. You will see probably six solenoid actuators in a bank on top of a black square tank. The tank probably has a chrome screw-off cap that has a built-in dipstick. You can only check the reservoir for transmission (hydraulic) fluid if the struts are retracted and the slide(s) in.
Each solenoid has an in-line bayonette fuse, usually 10 amps. Mine are in plastic water-resistent cases. Water seepapage can cause the fuses to corrode and fail. Ensure that the release valves on the back of each solenoid in closed (screwed in finger tight). These can vibrate slightly open and cause the hydraulic fluid to bypass the strut when under pressure. You can also loosen these valves to manually retract struts or slides.
Hope this helps.
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
1991 Explorer Sport 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS
Not overly concerned about depreciation with this rig...
nelson
Clio,Mi USA
Check the fluid level with all jacks up or you will overfill it.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
