RV.Net Open Roads Forum: Toy Haulers: Bias or radial?
Search only in Toy Haulers
 > Bias or radial?
wvabeer
West Virginia
Posted: 03/09/12 04:29am Link  |  Print  |  Notify Moderator
I am getting rid of my 225/75r15 load e Carlisle tires and thinking of getting a set of 6 bolt hole aluminum trailer wheels with 235/80/16 bias load e. Any thoughts on using bias tires?
UPDATE! the guy told me wrong they are Radials after all.
* This post was last edited 03/12/12 05:29am by wvabeer *   View edit history
1992 Airstream 33'landyacht M/H
12 Arctic cat Wildcat
08 Arctic cat Thundercat
03 Kawasaki 650 Prarie
01 FLHTC
midnightsadie
ohio
Posted: 03/09/12 05:09am Link  |  Print  |  Notify Moderator
either works but I prefer rad they ride better ,most important get the right load range ,and I prefer one step up. if load range C is good, I go D.
wvabeer
West Virginia
Posted: 03/09/12 05:59am Link  |  Print  |  Notify Moderator
I am getting a pretty good deal, I think. 190 each for new tire and wheel.
amxpress
Clayton, NC
Posted: 03/09/12 06:38am Link  |  Print  |  Notify Moderator
Though radials are a better tire, for the price you're getting them, not a bad deal.
You should, however, have them balanced before installing them.
Good luck.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
RJsfishin
Winston Or.
Posted: 03/09/12 05:30am Link  |  Print  |  Notify Moderator
The biggest advantage to radial tires is they run much much cooler than bias. If you never run in warm/hot weather, not a problem.
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
lincster
Mesa Az
Posted: 03/09/12 05:37am Link  |  Print  |  Notify Moderator
Just get 16" LT tires and be done.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Flattman
Arizona
Posted: 03/09/12 07:33am Link  |  Print  |  Notify Moderator
^^^ what linc said -
Tire and wheel for $190? Not sure I'd expect much in the way of a quality tire or wheel for that price - JMO
If you're moving to a 16" rim, go to an LT tire and be done. I'm of the opinion tires are not the place to be frugal. One nasty blowout can have you spending almost as much as the total you're looking at just for the insurance deductible to repair the damage.
Kudos for going in the right direction with your tires and wheels though. Peace of mind while you're towing is priceless...
Oh, and make sure your new wheels are rated for the air pressures associated with E rated tires (80-110 PSI depending on the tires you get).
Dodge Ram 6.7L 4X4 Quadcab W/Reese Slider
K-Z Inferno 3905 w/TrailAir
Carson 20' Enclosed Trailer
Sandwinder LTX Pro LS2 Sandrail
Yamaha Raptors
Honda TRX 450R
JIMNLIN
out here
If your upgrading to 16" wheels and tires I sure wouldn't put any brand ST tire back on the trailer that size.
As was suggested a LT225/75-16 E @29.3" diameter or LT235/85-16 E @ 31.5" diameter (if there's room under the wheel well) will be the best upgrade.
Bias ply tires are ancient tech. Their better suited for lawn service trailers for around town runs or a trailer out on the farm.
'97 Park Avanue 28' 5er 11200 gvwr two slides
skipnchar
Topeka or somewhere else
Posted: 03/09/12 08:23am Link  |  Print  |  Notify Moderator
Bias tires will work OK but will run hotter than radials and likely will wear faster. Heat is hard on an ST rated tire because of all of the lateral forces they under-go when taking any corner. I like the extra safety of the radial on my trailer. Never had a blow out in 80,000 towing miles and want to keep it that way. No Chinese made tires on my rig either Maxxis all the way.
Good luck / Skip
ScottG
Bothell Wa.
Posted: 03/09/12 10:07am Link  |  Print  |  Notify Moderator
I've found that radial trailer tires have a lot more grip when it comes to stopping.
Scott, Grace and Wesly
H0NDA eu2000i
 > Bias or radial?
