RV.Net Open Roads Forum: Fifth-Wheels: Manual Landing Gear attachment for Drill
 > Manual Landing Gear attachment for Drill
josten367
Columbia, MO
Posted: 03/09/12 08:02am Link  |  Print  |  Notify Moderator
Does anyone have a good idea on how to use an electric drill or cordless drill to lower and lift landing gear?
I have seen a few online but they are costly and I don't want to have to carry extra blocks in the truck because of the weight. I have thought about making my own with an socket chuck and cut a slot in an old socket.
2012 Palomino Puma Bunkhouse 5th Wheel 295KBH
2003 Chevy Silverado 2500HD Crew Cab 4x4 Gas with Flowmasters
B&W Companion 5th Wheel
Macktee
Canada
Posted: 03/09/12 08:07am Link  |  Print  |  Notify Moderator
I had a machinist make up a rod and weld a socket on to it and then used it in my DeWalt. Worked great when I had the 5er. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2013 Cargo Mate 28ft enclosed car hauler
2013 Hyundai Elantra GT
2010 Club Car Golf Car
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 03/09/12 08:21am Link  |  Print  |  Notify Moderator
is this for a trailer without electric landing gear??
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
agesilaus
North Florida
Posted: 03/09/12 08:56am Link  |  Print  |  Notify Moderator
I did it on our TT and it worked fine. The shaft for the jacks was a hex head and I just found the right socket. It shouldn't be hard to fab something to fit yours. The Harbor Freight cordless was generally worthless tho. The battery would not hold a charge more than a day or so.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
jalichty
Lander, Wyoming 82520
Posted: 03/09/12 08:57am Link  |  Print  |  Notify Moderator
I don't see why Macktee's idea won't work just fine. That's for the front. For the rear jacks, you can just cut off the business end, leaving a little rod and then grind the round sides off to fit your drill and use that to lower and raise the rear jacks. After many years, I did that, then kept forgetting the drill so had to use one of the tools and got no help from DW.
John A. Lichty
josten367
Columbia, MO
Posted: 03/09/12 09:49am Link  |  Print  |  Notify Moderator
This is for our 5th wheel trailer (see below info) for the front landing gear.
I already have one for the rear (hex head) but the front has the special round socket with a slot on both ends.
big bird 2
La Crescenta, CA
Posted: 03/09/12 10:00am Link  |  Print  |  Notify Moderator
I have electric landing gear. I found the landing gear,slide gear box and stabilizer box all have the same size manuel hex head. I purchased one separate socket and a 6 inch extension and use my drill. I did not have to do anything special.
Big Bird 2
Mitchellg
St.Louis
Posted: 03/09/12 11:48am Link  |  Print  |  Notify Moderator
drill chuck to 3/8ths socket adapter to 3/4" socket on my craftsman 19.2v drill works great for me. Snugs up and undoes the rear stabilizers great in about 20 seconds. Total cost was $3 for the adapter.
laknox
Arizona
Posted: 03/09/12 11:56am Link  |  Print  |  Notify Moderator
My plan, one of these days, is to buy another hand-crank like the one that came with my FW, cut it off right below the "handle" bend, and simply chuck it up in my drill. Need be, I'll grind some flats on it to keep it from spinning in the chuck. Unfortunately, mine doesn't use a simple hex-head on the gear-box, so I can't use a socket.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 60 Year Member
the bear II
Torrance CA.
Posted: 03/09/12 03:11pm Link  |  Print  |  Notify Moderator
Make sure your drill has enough power to crank when the full weight of the trailer gets on the landing gear. I carry a 14V Black & Decker cordless drill and put together a socket, adaptor and extension to use only to discover the drill doesn't have enough power to go beyond just touching the ground with the stabilizers in the rear.
My 18v Porter Cable cordless works fine so now I carry it.
