RV.Net Open Roads Forum: Tech Issues: Xantrex with all lights blinking
 > Xantrex with all lights blinking
Commerce
Alabama
Posted: 03/09/12 08:40am Link  |  Print  |  Notify Moderator
On my 2004 Tiffin Phaeton I have a 2,000 Watt Xantrex converter charger with the freedom remote up front. The other day when I went in the rig I noticed every light on the panel blinking back and forth not at the same time just randomly. The rig was plugged in and AC was running fine etc. I went back in the rig last night and it was still doing that so my question is has anyone else ever seen this kind of thing happening with their Xantrex and if so what do you suggest that I do ?
garym114
Bluff Dale, Texas
Posted: 03/09/12 12:47pm Link  |  Print  |  Notify Moderator
Try disconnection from shore power and reconnecting.
gatorcq
Arizona
Posted: 03/09/12 04:51pm Link  |  Print  |  Notify Moderator
Also disconnect the telephone type plug from the unit.
As for disconnecting from shore power, the unit is mainly power by DC (inverter batteries).
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 08 Jeep Liberty
Roadmaster and Air Brake System
1600Ws MPPT, 2800Ws Inv/Chg, 660AH
Alfa SeYa 2003, CAT 3126E 330Hp (Previous)
DaGirslRV Blog
dougrainer
Carrolton, Texas
Posted: 03/09/12 08:47pm Link  |  Print  |  Notify Moderator
Disconnect the Shore Power and then disconnect the 12 volt positive battery cable from the Inverter for 5 minutes. Then reconnect the battery cable and reconnect the shore power and after this, your Inverter will be OK. It just needed a "reboot" by removing all power for 5 minutes, a common problem. Doug
Commerce
Alabama
Posted: 03/10/12 08:45am Link  |  Print  |  Notify Moderator
I will try the hard re-start and see if that works unplugging everything. I just thought it was strange all lights were blinking back and forth like that.
