RV.Net Open Roads Forum: Tech Issues: 1991 Chevy P30 radiator is shot!
 > 1991 Chevy P30 radiator is shot!
swp5767
Royal Palm Beach, FL
Posted: 03/12/12 08:36am Link  |  Print  |  Notify Moderator
To add a little more info to this project.
A local auto parts store can get me a 2 row copper and brass radiator for $265. They say that todays 2 row are as good as the older 4 row radiators.
Anyone else agree with that?
Ozlander
Rose Hill, Kansas
Posted: 03/12/12 08:40am Link  |  Print  |  Notify Moderator
NO!!!!
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Our Place
Southwest Ohio
Posted: 03/12/12 09:18am Link  |  Print  |  Notify Moderator
Two rows in aluminum is way better than two row in coppper! The reason is that the core tubes are wider. Most aluminum radiators for heavy trucks is only two row but measure the same as a four row in copper. If you have a "cross flow" then the number you need for a "P-30 motorhome cassis" not a bread truck is 431338 from ready-rad. This is aluminum and plastic cross flow with a remote fill cap (cap not on the tank directly).
2001 GMC 2500HD 4x4 with 8.1 gas Allison trans
2011 Coachman Chaparral 268RLE "Campy"
swp5767
Posted: 03/12/12 10:59am Link  |  Print  |  Notify Moderator
Yes, The cap is on a short hose connected on the front. I looked up the number above. The measurements are an inch smaller in both directions. Im sure I can still make that work.
I found ready-rad at some different suppliers for different prices. Do you recommend anyone to buy from?
swp5767
Posted: 03/12/12 02:47pm Link  |  Print  |  Notify Moderator
NO!!!!
An radiator seller in OR tells me the newer radiators with 2 rows have wider tubes in them. They 2 1" tubes where mine has 4 1/2" tubes. The total tube width is the same as long as the core is 2+" thick.
Our Place
Southwest Ohio
Posted: 03/13/12 09:24am Link  |  Print  |  Notify Moderator
I got mine new from my local Carquest store but I did have to find my own number for it cause they kept finding radiators for bread trucks! I still have my old good one here and measured it.. it is 29 inches wide and 21 inches tall and this is at the flanges where the tanks are attached. Inlet hose-top left/outlet hose-bottom right/hose for heater return-top right rear side/hose for cap-top right front side. My coach was a 1993 Southwind "P" chassis, hope this helps
swp5767
Posted: 03/15/12 05:56pm Link  |  Print  |  Notify Moderator
I picked up this radiator from a local auto parts store today and got it installed. So far so good!!
Thanks again for the help!
