RV.Net Open Roads Forum: Tech Issues: Help--Generator Starting on it's own !
 > Help--Generator Starting on it's own !
USMC46
Posted: 03/09/12 07:32pm Link  |  Print  |  Notify Moderator
I returned home this evening and after a few minutes heard someting like a truck in my back yard. No truck...my Onan diesel generator in my coach was running. It had started on it's own. I went inside and switched the toggle switch to turn it off and it turned off. Any ideas ? Bad toggle switch maybe ?
Jim & Carmel
http://sayreodyssey.blogspot.com/
2004 Dutch Star 41'
2006 Jeep Liberty
Blue Ox Aventa Tow Bar
Brake Buddy
rexlion
Broken Arrow OK
Posted: 03/09/12 07:46pm Link  |  Print  |  Notify Moderator
Not sure what started it, but you might want to pull the spark plug wire off until you get it diagnosed.
past-MIdirector
Michigan
Posted: 03/09/12 07:48pm Link  |  Print  |  Notify Moderator
Is your rig equipped with a low battery auto start generator? A lot of the newer rigs are equipped with this system.
wolfe10
Posted: 03/09/12 07:49pm Link  |  Print  |  Notify Moderator
If no auto gen set start, check for water in your on-generator start switch or wiring at the generator end of the wires that go to the in-coach start switch.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
steveownby
Cosby, TN
Posted: 03/09/12 07:51pm Link  |  Print  |  Notify Moderator
I assume you don't have auto gen start. Onan 7.5kw generators have been known to self start if moisture gets into the multi wire plug on the outside of the generator box. You might shoot some di-electric grease into the plug.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
ohio4whlr
central ohio
Posted: 03/09/12 08:13pm Link  |  Print  |  Notify Moderator
Diesel gen. No spark plugs, also just pulling plug wire won't keep it from cranking.
dougrainer
Carrolton, Texas
Posted: 03/09/12 08:28pm Link  |  Print  |  Notify Moderator
1. Diesels do NOT have spark Plugs
2. BAD IDEA, If it cannot start, what happens to the starter or ring gear???????
3. To the OP, DISCONNECT the remote harness at the APU and check for corroded pins inside that connector. Onan Diesel remote connects at the APU are notorious for corroding out even with the rubber seals on the matching plugs.
4. If it starts after the remote plug is checked (OK) and you leave it disconnected, then water got into the switch/breaker housing area. Some Onan Diesels will start if water gets inside that housing. Doug
TEXAS
Centerville Tx
Posted: 03/10/12 06:36am Link  |  Print  |  Notify Moderator
You guys take it easy on the spark plug guy. He is from Oklahoma.
