Backman
Newport News, VA
Does anyone put something between the top of the slide out and the topper to keep them from sagging. We had toppers on our motorhome and they lasted for six years before I had to replace them, they did sag some but no problems. We just purchased a new fifth wheel and was just curious if you put something between the slide out and the topper to keep the rain from building up on them. Thanks in advance for any advise.
Larry and Debbie
2012 Sanibel 3500
"HPY RVN"
Dick_B
Palos Heights, IL USA
We don't but probably should. But it's too much trouble to carry something around to prevent the sag which goes away when the slide is brought in anyway. In heavy rain/wind I throw a rope over the cover and tie it down at both ends to make a trough to let the rain drain and/or keep it from flapping. This can be done from the ground.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
bogart661
Canyon Country, CA
You could try one of these Link
2013 2WD Chevy Silverado LTZ 3500HD Crew Cab Short Bed Duramax/Allison
2001 Lakota 28 RKD 100w solar
skipnchar
Topeka or somewhere else
Probably not necessary as long as the topper has some elevation to it. If it is relatively flat (parallel to the slide room roof) then it might help some).
rolnhome
Casa Grande, Az
A small beach ball or a gallon milk jug slid under the topper works pretty well.
We're in Arizona
Backman
Newport News, VA
Thanks for the responses, I had thought about a small blow up ball like a beach ball but I had not thought of a rope around the topper. It has some elevation but not much, I just did know if it would stretch too much. Thanks again!
Mile High
Denver, CO
Ah - the saga of trying to figure out what you can add to make your add-on work
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Ranger Smith
Wherever the rig is parked
I put nothing underneath and mine don't sag. I installed them myself and gave a little more than of a pitch on them.
Where I Am Now
Amateur Radio Operator W0SPS ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
mobilcastle
OH
After reading this thread I don't think I want slide toppers-seems like too much of a problem.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
tvman44
Southwest Louisiana
I just close the slide after a heavy rain and the water drains off then reopen. I would not be without slide toppers.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
