RV.Net Open Roads Forum: Fifth-Wheels: Slide Out Toppers
 > Slide Out Toppers
Backman
Newport News, VA
Posted: 03/09/12 07:58pm Link  |  Print  |  Notify Moderator
Does anyone put something between the top of the slide out and the topper to keep them from sagging. We had toppers on our motorhome and they lasted for six years before I had to replace them, they did sag some but no problems. We just purchased a new fifth wheel and was just curious if you put something between the slide out and the topper to keep the rain from building up on them. Thanks in advance for any advise.
Larry and Debbie
2012 Sanibel 3500
"HPY RVN"
Dick_B
Palos Heights, IL USA
Posted: 03/09/12 08:12pm Link  |  Print  |  Notify Moderator
We don't but probably should. But it's too much trouble to carry something around to prevent the sag which goes away when the slide is brought in anyway. In heavy rain/wind I throw a rope over the cover and tie it down at both ends to make a trough to let the rain drain and/or keep it from flapping. This can be done from the ground.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
skipnchar
Topeka or somewhere else
Posted: 03/09/12 08:16pm Link  |  Print  |  Notify Moderator
Probably not necessary as long as the topper has some elevation to it. If it is relatively flat (parallel to the slide room roof) then it might help some).
rolnhome
Casa Grande, Az
Posted: 03/09/12 08:38pm Link  |  Print  |  Notify Moderator
A small beach ball or a gallon milk jug slid under the topper works pretty well.
We're in Arizona
Backman
Newport News, VA
Posted: 03/09/12 09:02pm Link  |  Print  |  Notify Moderator
Thanks for the responses, I had thought about a small blow up ball like a beach ball but I had not thought of a rope around the topper. It has some elevation but not much, I just did know if it would stretch too much. Thanks again!
bogart661
Canyon Country, CA
Posted: 03/09/12 09:45pm Link  |  Print  |  Notify Moderator
You could try one of these Link
2013 2WD Chevy Silverado LTZ 3500HD Crew Cab Short Bed Duramax/Allison
2001 Lakota 28 RKD 100w solar
Mile High
Denver, CO
Posted: 03/09/12 09:53pm Link  |  Print  |  Notify Moderator
Ah - the saga of trying to figure out what you can add to make your add-on work
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Ranger Smith
Wherever the rig is parked
Posted: 03/10/12 05:57am Link  |  Print  |  Notify Moderator
I put nothing underneath and mine don't sag. I installed them myself and gave a little more than of a pitch on them.
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
mobilcastle
OH
Posted: 03/10/12 06:01am Link  |  Print  |  Notify Moderator
After reading this thread I don't think I want slide toppers-seems like too much of a problem.
2010 Heartland 3670RL Demco,dual panes,2-AC,
7000lb axles,G rated LT tires,38' high profile,
2011 Chevy 3500HD,Dually,D/A,LB,EB,4X4,
B&W Companion,GVWR-13,000
tvman44
Southwest Louisiana
Posted: 03/10/12 06:34am Link  |  Print  |  Notify Moderator
I just close the slide after a heavy rain and the water drains off then reopen. I would not be without slide toppers.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
 > Slide Out Toppers
