RV.Net Open Roads Forum: Class A Motorhomes: Single 6 Volt Golf Cart Battery?
 > Single 6 Volt Golf Cart Battery?
Page of 5
briantroy
San Diego, CA, USA
Posted: 03/09/12 11:46pm Link  |  Print  |  Notify Moderator
I have a conversion van that I use once or twice a month for camping. My power needs are limited: a fan, a small radio, a couple lights and a blender for margaritas. I have been through two $100 deep cycle/marine batteries and they lasted me about 3 years each time. The aux battery is mounted under the van amd receives it's charge from an isolator connected to the alternator. I live in a condo and cannot charge the battery from an outlet at home.
I have heard that these marine/deep cycles are not "true" deep cycle batteries and that 6 volt golf cart batteries are "true" deep cycle. I think the problem I have is that after a dozen or so margaritas the lights, radio and fan stay on all night and it puts a serious drain on the battery (unless 3 years and 25 camping trips is normal?)
Because my power needs are limited and I am sure the battery will be severely drained again, I am wondering if I should (or can) switch over to a single golf cart battery. Will the inverter still work? I would go with 2 in a series, but I want to stay on a budget and I am not running anything important.
Thanks!
* This post was last edited 03/14/12 09:24pm by briantroy *   View edit history
ArchHoagland
Clovis, CA, USA
Posted: 03/10/12 12:46am Link  |  Print  |  Notify Moderator
A single 6 volt battery?
Is that what you are asking?
I don't think so Tim.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Golden_HVAC
Fulltime, CA, USA
Posted: 03/10/12 01:03am Link  |  Print  |  Notify Moderator
Hi,
You can not use a single 6 volt battery to power a 12 volt system. They are used in easy to carry pairs, making 12 volts by using a pair in series to make a total of 12 volts.
The alternate is a single 8D battery - 120 pounds in one not so easy to carry battery, with the same water capacity as a pair of golf cart batteries.
What might work better is a 5SP - it is a little larger than the group 27, a littler taller, longer and wider. It is also 85 pounds, and rated at about 185 amp hours. I put one in a manlift, and it lasted for several years.
If you can fit in a group 31, it will store more energy than the 27.
If you buy a 195 watt solar panel, it will recharge the battery the next day, and help prevent sulfates from building up on the plates, and this will lead to a really long battery life.
SunElec.com sells the 195 watt for $263.
Fred.
briantroy
San Diego, CA, USA
Posted: 03/10/12 01:20am Link  |  Print  |  Notify Moderator
Thanks, that helps! I just realized I don't have room for two 6 volts anyway. I think I have been using a group 24 and that barely fits. Because I don't use much power, but need the reliability after draining most of the power, a 12 volt golf cart battery group U1 would be a better fit. Any suggestions on a brand?
GPWayne
Lake Stevens. WA
Posted: 03/10/12 01:21am Link  |  Print  |  Notify Moderator
You need 12 volts!....One 12 volt battery or Two 6 volt batteries.
(You can find 12 volt true deep cycle batterys $$$)But they don't like starting an engine too much. Thats why so called "deep cycle/marine batteries" are used.
Three years or less is about what you can expect when deep discharging a battery again and again.
I have seen a gas powered blender....For use outside only.
Also you could use a small Honda Gen.
briantroy
San Diego, CA, USA
Posted: 03/10/12 01:38am Link  |  Print  |  Notify Moderator
Thought about the generator, but the beach campgrounds here in San Diego don't care for them! 3 years is normal for the marine/deep cycle batteries then? Maybe I didn't kill them, they were just at the end of their life then. I was hoping to get more than 3 years out of a "true" deep cycle, just wondering now if the price is worth the extra $$$.
garym114
Bluff Dale, Texas
Posted: 03/10/12 04:47am Link  |  Print  |  Notify Moderator
Any battery, 6v or 12v, will have a much shorter life if allowed to discharge below 50%. Any battery will have a shorter life if allowed to stay in a discharged condition.
gbopp
The Keystone State
Posted: 03/10/12 06:01am Link  |  Print  |  Notify Moderator
Read The 12 Volt Side of Life, it will help you understand your batteries.
skipnchar
Topeka or somewhere else
Posted: 03/10/12 07:02am Link  |  Print  |  Notify Moderator
There is no way to get 12 volts from a single 6 volt battery (that is practical anyway). You would need a pair of them to equal 12 volts. Sounds to me like you're getting about what would be expected of a starting battery from your marine/RV batteries. They are not designed to ever be USED to be a total power source in your RV other than for loading or quick lunch stops. For dry camping you'll need more battery power and preferably better batteries.
Good luck / Skip
CA Traveler
The Western States
Posted: 03/10/12 07:06am Link  |  Print  |  Notify Moderator
Given this I dont' understand why you are concerned about the battery. Just replace it every 3 years.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
Page of 5
