RV.Net Open Roads Forum: Class A Motorhomes: Single 6 Volt Golf Cart Battery?
 > Single 6 Volt Golf Cart Battery?
Page of 5
pianotuna
Regina, SK, Canada
Posted: 03/10/12 09:42am Link  |  Print  |  Notify Moderator
Hi,
Add a solar charging system.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Wherever I happen to park
Posted: 03/10/12 10:16am Link  |  Print  |  Notify Moderator
There is a device you can get that hooks to your battery
here are a couple of options you should look at, NOTE: I found these by an internet search I have no expierence with either product.
Option one Priority Start
Option two, Intelletec's entry, this is a PDF file
A device of the type described above will cut off the battery if the voltage goes too low thus protecting the battery, at the cost of such things as radio memory, and if you use it on your starting battery engine and transmission computer memory if any such exists. (some of them "learn" some do not).
othertonka
Stockton, CA
Posted: 03/10/12 02:11pm Link  |  Print  |  Notify Moderator
I don't understand why you need the lights, radio, and fan ALL night.
Turning these off will save a lot of the drain on the battery and then make sure you recharge the battery right away when you can, a battery stored in a discharged state shortens it's life.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
briantroy
San Diego, CA, USA
Posted: 03/10/12 04:30pm Link  |  Print  |  Notify Moderator
Sometimes the party lasts all night and sometimes I forget after too many margaritas. The battery storage is mounted under the van and receives it's charge from an isolator connected to the alternator. I live in a condo and don't have access to charge from an outlet at home. If I camp close and only drive for half an hour, I don't think the battery is getting a full charge right away. I will usually drive the van to work and around town the following week and hope it gets charged again. Just thinking a "true" deep cycle might be better for this abuse.
pianotuna
Regina, SK, Canada
Posted: 03/10/12 04:40pm Link  |  Print  |  Notify Moderator
Hi,
Solar will make sure the house battery starts every trip fully charged.
CA Traveler
The Western States
Posted: 03/10/12 04:51pm Link  |  Print  |  Notify Moderator
Well the OP likes his partys etc and isn't into battery maintenance. So why advise him on expensive solar, etc? That would be a lot of margaritas!
Just replace the battery every 3 years.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
pianotuna
Regina, SK, Canada
Posted: 03/10/12 04:56pm Link  |  Print  |  Notify Moderator
Hi CA,
Just 30 watts of solar will keep his battery bank fully charged between trips. That will not be expensive at all.
briantroy
San Diego, CA, USA
Posted: 03/10/12 04:59pm Link  |  Print  |  Notify Moderator
I park the van in an outdoor condo parking lot, far from outlets, so a solar kit might be the right way to go. As far as maitenance, I am partially disabled and cannot drop the mounting that stores the battery, so I prefer as little maitanence as possible. Just wondering if there are cheap solar units out there. I live in sunny San Diego and only use the van once or twice a month so I don't need a quick charge, just looking for the best system that will suit my needs and budget. Thanks for all the input guys!
SteveAE
Bend, Oregon
Posted: 03/10/12 05:09pm Link  |  Print  |  Notify Moderator
Hi,
As others have said, add a small solar system.
Also:
- Get a hand cranked blender (that blender is using a lot of power)
- Install LED lights (your lights are most likely >50% of your total load)
Doing the above (assuming you don't have the radio blaring at full volume), should reslove all you power problems. Only problem is then you will likely come up with other things to run
Have fun,
Steve
briantroy
San Diego, CA, USA
Posted: 03/10/12 08:14pm Link  |  Print  |  Notify Moderator
Thanks everyone. Think I will go with another sealed group 24 marine/deep cycle from Costco and add a small solar charger. Hopefully that will extend the life beyond 3 years.
Page of 5
