RV.Net Open Roads Forum: What's high mileage for a 7.3 power stroke diesel?
Search only in Tow Vehicles
 > What's high mileage for a 7.3 power stroke diesel?
Atlee
Mechanicsville, VA
Posted: 03/10/12 04:37am Link  |  Print  |  Notify Moderator
What would be considered high mileage for a 2001 F250 supercab 4x4 pickup with the 7.3 PowerStroke diesel engine? The one I'm looking at has 183K miles on it. Also a new Ford transmission with 75K warranty was just put in it. The oil has been changed every 5k miles, and every 30k miles it was taken in to the dealer for any major service/maintenance items.
I could get it for $11,000.
Erroll, Mary, Duffy the Dachshund (RIP)
www.thetravelingkoala.blogspot.com
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
Wills6.4 Hemi
meadows
Posted: 03/10/12 04:41am Link  |  Print  |  Notify Moderator
my niehbor has 500k with no internal engine problems.
turninghawk
Ormond Beach, FL
Posted: 03/10/12 04:42am Link  |  Print  |  Notify Moderator
You need to worry about the rest of the truck wearing out way before you worry about a 7.3PSD wearing out.
SoCalDesertRider
Arizona desert
Posted: 03/10/12 04:52am Link  |  Print  |  Notify Moderator
I wouldn't be so concerned about the diesel engine. Your concern should be focused on the rest of the truck, particularly the front end and tranny. Sounds like the tranny has been addressed.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
byrdr1
Elon, NC / Central Piedmont
Posted: 03/10/12 05:21am Link  |  Print  |  Notify Moderator
My 2003 7.3 has 185K on it now. Oil changed every 6000 to 8000 miles. trans mission serviced every year just before first trip out with camper. All new brakes and rotors last year. front end work almost 2 years ago now. New bushings, upper and lower ball joints with zerks on the front end, that heavy steel bar across the front end( i cant think what is called). rear seals last year. replaced the strut things(then hang down from frame) on the front end. I need shocks now. I have had used this truck for towing and anything else I have needed. If it has been taken care off I think you would be getting a good deal..
JMHO
randy
2003 F-350 SRW CC/LWB 4X4 7.3PSD
2011 Keystone Cougar 327RES
Happy Campin'
Randy
Piedmont area of NC
NewsW
US
Posted: 03/10/12 05:35am Link  |  Print  |  Notify Moderator
10,000 hours at 50% load is high.
That is about 500,000 miles of normal driving.
183,000miles is roughly at 1/2 of the B50 life of about 500,000 miles.
Unless it was used for heavy towing, that would also explain the premature transmission failure.
The things that are worn:
Hoses, belts, tires, anything rubber or plastic, thermostat, interior fittings, dash, carpet, seat, trim, etc. all of which are expensive to fit.
Esp instrument panel bulbs and other very time consuming things to fix.
If used in salt areas, salt damage.
nremtp143
Georgia
Posted: 03/10/12 05:39am Link  |  Print  |  Notify Moderator
My '01 Excursion has 176k on the clock now and has a lot left to go. You can't even find used 7.3s around here for under the 15-16 range that are in good condition. The 7.3s will go 500k with good maintenance. The problems with those year models lie in the front end as already pointed out. Ball joints and tie rod ends. Once replaced-no worries. If you are going to pull a great deal with it, you will need to upgrade the transmission cooler to the 6.0L cooler( a matter of swapping the coolers and adding 2 reducer connections) or buy an after market one rated to pull upwards of 25k. They keep the transmission from over heating. I wouldn't hesitate to buy the truck at that price if it is in decent shape. As was said earlier, the engines may out last the truck.
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
EMD_DRIVER
Gerrardstown, WV
Posted: 03/10/12 08:04am Link  |  Print  |  Notify Moderator
My 99 has 313,000 miles on it.. One of the previous owners wasn't very good at maintenance and the rear differential is being replaced right now.. I would not hesitate to buy the truck you are looking at. Take care of the things already mentioned and do the proper maintenance. he truck might outlast you... Just remember to always keep a 10mm socket and ratchet, along with a new CPS in the glove box... They are the weak spot in the 7.3 and very easily replaced.
I have a friend, that used to haul travel trailers from the factory and to the dealers. His 7.3 went 540,000 miles, before it needed any engine work. All it needed at that time, was new injectors.
2007 Excel 30RKE fifth wheel
2011 Ford F250 6.7l
SoCalDesertRider
Arizona desert
Posted: 03/10/12 08:29am Link  |  Print  |  Notify Moderator
JMHO
randy
The heavy steel bar that runs across the front of the truck in front of the axle is the tie rod.
The '03 F350 4x4 in your signature doesn't have struts in the front end. There is a monobeam axle (Dana 60), which is located by a pair of leaf springs and a transverse tracking arm (goes from one side of the frame to opposite side of the axle, above the axle). There is also a sway bar, which connects to each side of the axle, behind and above the axle. There are a pair of shocks connected to the axle, as well as a driveshaft, and a drag link for the steering that connects between the steering arm and the tie rod.
There are a pair of end links that go up from each end of the sway bar to each frame rail of the truck. Perhaps it is the sway bar end links you are referring to? Typically, the sway bar and end links are not replaced during the life of the vehicle, but the rubber bushings at each end of each link, as well as the rubber bushings where the sway bar mounts to the axle, can be replaced.
bmanning
Phoenix, AZ
Posted: 03/10/12 08:34am Link  |  Print  |  Notify Moderator
This.
Things like power window motors, windshield wiper motors, power seats, HVAC issues, etc. will crop up long before that 7.3L gets tired.
Of course, for $11g, you could keep a nice "repair fund" on the side for when those things go.
Sounds like it's been well-cared-for in general, and having the transmission addressed already is huge.
BManning
baking in Phoenix ">
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
