RV.Net Open Roads Forum: Fifth-Wheels: Lubricating black and grey water tank dump valves
 > Lubricating black and grey water tank dump valves
Carlope
Anderson,Indiana
Posted: 03/10/12 09:14am Link  |  Print  |  Notify Moderator
Has anybody ever tried dumping vegetable oil or canola oil in to the waste tanks to lubricate the valves. I know you can buy the lube i believe from Camco. I believe it has coconut oil in it.
Just a thought i just wondered if this would work as well.
2002 Forest River Sandpiper RL30SS
2004 Chevy 2500 HD D/A
Prodigy Brake Ctrl
It takes a mighty BIG DOG to weigh a TON
korbe
Northern California
Posted: 03/10/12 09:32am Link  |  Print  |  Notify Moderator
I placed some oil on the stem and worked it back and forth a few times. Seemed to help a little.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
MTPockets1
Posted: 03/10/12 03:04pm Link  |  Print  |  Notify Moderator
I had always thought that just about everything flowing past that valve was naturally oily and that no lube was necessary.
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
wittmeba
Virginia
Posted: 03/10/12 10:00am Link  |  Print  |  Notify Moderator
Try the GEO method: See here and scroll down.
http://www.rvecafe.com/bwater.html
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 01/12/2013
JoeGood988
S.Dakota
Posted: 03/10/12 10:09am Link  |  Print  |  Notify Moderator
I added a grease zerk to the flat side of the valve...shoot some grease in there, work it back and forth...works smooth....if it feels a little sticky, just shoot a little more grease
2003 3330 Jayco Legacy
Pond Jumper
North Texas
Posted: 03/10/12 12:58pm Link  |  Print  |  Notify Moderator
I use my liquid laundry detergent. Add some water with it in the sink, toilet to make it thinner. Go out side and try to open and close the valve as fast as possible a few times. Works for me.
tsetsaf
Full-Timer
Posted: 03/10/12 11:16pm Link  |  Print  |  Notify Moderator
I find that a few bean burritos from tacobell lubricates the black ta... oh wait wrong topic
'06 Dodge 3500 5.9L CTD 6spd Manual SB SW - Pullrite SG - Ride Rite Airbags
RV Park and Campground Directory
'06 Keystone Challenger 37' 4 Slide 5th
Chuck&Gail
In the Colorado Mountains
Posted: 03/10/12 03:32pm Link  |  Print  |  Notify Moderator
Yes, commercial valve lube seems to just be coconut oil. I've tried vegetable oil, and conola, they all work. BUT, I discovered that olive oil works better than anything else I've tried, so I use it. Difference was easy to see in the toilet valve operation come spring. With olive oil there was no leakage past toilet valve, and it wasn't sticky at all when first used, smooth as silk.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
majorloser
Central Florida
Posted: 03/10/12 03:46pm Link  |  Print  |  Notify Moderator
My wife will just love me stealing her extra virgin olive oil to pour down the toilet.
2010 Ram 2500 Megacab Laramie w/Cummins
Firestone R4Tech rear suspension
Pullrite SuperGlide 18K w/ Bedsaver
2012 KZ Durango 1500 D295CS
larry barnhart
wenatchee. wa usa
Posted: 03/10/12 07:09pm Link  |  Print  |  Notify Moderator
I have used vegtable oil 3 times since 2001. Empty black tank and pour one gallon down the toliet and let it sit for awhile and then pull and push the handle in and out quicky to drain. this has made ours work easy and smooth.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
