RV.Net Open Roads Forum: Beginning RVing: Slides
 > Slides
Barry514
San Diego
Posted: 03/10/12 09:40am Link  |  Print  |  Notify Moderator
New to slide outs, what do people use to put on the slide out as far as lub?
n7bsn
Yes
Posted: 03/10/12 09:47am Link  |  Print  |  Notify Moderator
RTFM
Read The Fine Manual
Honestly, the builder of the slide will give you what type of lube to use, and they are much more likely to be right then a bunch of Internet X-perts who don't even know which model or maker it is.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
fordsooperdooty
Posted: 03/10/12 09:50am Link  |  Print  |  Notify Moderator
Lippert Slideout Componants is one of the biggest slideout manufacturers, and they say not to grease or lube the slideout Mechanism. Tests show that after thousands on in-out test cycles the slideouts still operate properly without lubricants.
Keep it clean using soap and water, and if it should become balky or noisy use a dry lube such as Rem-Oil Dry Teflon or Slip Plate Dry Graphite spray.
The #1 cause of issues with slideouts, per Lippert is the mechanism becoming clogged with road debris sticking to the grease. #2 most common issue is loose, dirty or corroded electrical terminals.
Barry514
San Diego
That would be good if I had the owners manual. Have been trying to find one but to know avail.
n7bsn
Yes
Posted: 03/10/12 10:16am Link  |  Print  |  Notify Moderator
Barry, what brand rig? what type? gear-driven? cable drive? Hydraulic ? Some
description?
I will bet, someone can figure out the brand if you provide more info
Barry514
San Diego
Posted: 03/10/12 10:19am Link  |  Print  |  Notify Moderator
2002 Sea Breeze, 30' Appears to be gear driven.
n7bsn
Yes
Posted: 03/11/12 09:57am Link  |  Print  |  Notify Moderator
Barry, I'm going to GUESS it's the same as my exposed gear system. I use a dry-lube, Teflon based
Barry514
San Diego
Posted: 03/11/12 10:08am Link  |  Print  |  Notify Moderator
n7bsn
I think you are correct. Looking under the slide, I see two rails with teeth so I am guessing it is like your. Gear drive
THANKS for your reply.
 > Slides
