RV.Net Open Roads Forum: Class A Motorhomes: Problem with air leveling system
 > Problem with air leveling system
MSHappyCampers
Columbus, MS
Posted: 03/10/12 11:49am Link  |  Print  |  Notify Moderator
The HWH air leveling system on my coach has a problem. When I set it to automatically level the coach, the amber light for the rear will never go off, showing the rear to be low. I have checked with a level and the coach is perfectly level, even though the light is on. Anyone else ever have this problem?
Joe & Annette
2002 Monaco Windsor 40PBT
MaverickBBD
Formerly of Bellingham, Wahington, U.S.A.
Posted: 03/10/12 12:30pm Link  |  Print  |  Notify Moderator
Not sure where it it located on your coach. On mine it is behind the front left wheel. There is a simple adjustment for right-left and fore-aft. Make sure your coach is level and then make the needed adjustment until lights go out. Maybe HWH can help you locate it.
Tom, Cheryl & Blossom(coonhound mix)
'05 Winnebago Journey 36G w/Cat. C-7 350 hp Freightliner XC
AFE air filter, aero turbine muffler, 4 FSD Konis, ultra track bell crank and Safe-T-Plus
FMCA 397030
WIT 129107
azpete
paulden
Posted: 03/11/12 08:47am Link  |  Print  |  Notify Moderator
on your coach, the level sensor is normally mounted in the overhead of one of the middle storage bays. look for a removable panel in one of the bays. lots of fun to locate and adjust. it should be located in the top ring of the two ring control box. you may need a small mirror to see it. if its the old style round sensor, you may need two people to adjust it quickly.
* This post was edited 03/11/12 08:55am by azpete *
dashdriver
Colorado
Posted: 03/11/12 08:55am Link  |  Print  |  Notify Moderator
I have a panel in the roof of my front bay that comes off, revealing the leveling unit. Mine needs a minor adjustment but haven't done it yet.
1999 HR Navigator 42DSS
2008 Jeep Wrangler Unlimited (4Dr)
MSHappyCampers
Columbus, MS
Posted: 03/10/12 05:10pm Link  |  Print  |  Notify Moderator
The tech at HWH said there was a sensor block located above one of the storage bays, but he doesn't know which one. I am calling Monaco monday to see if they can tell me which bay. All the bays are closed overhead so I don't want to remove the wrong one! Thanks!
rvrepairnut
bc
Posted: 03/10/12 12:32pm Link  |  Print  |  Notify Moderator
99% of them are located in the roof of the storage compartments midship and that where u take your reading and ajust accordingly
whopps just noticed u said AIR leveling.Last time I worked on that system there are two sensors right above the front and rear axles and in the middle of the unit.
* This post was edited 03/10/12 05:29pm by rvrepairnut *
