RV.Net Open Roads Forum: Class C Motorhomes: Just starting Class C Questions
 > Just starting Class C Questions
Holiday27
Gresham, OR.
Posted: 03/11/12 07:57pm Link  |  Print  |  Notify Moderator
We have a 02 HR but it's a 27ft. We love it. I like the fact that it has aluminum sides and alum roof. You won't have to worry about the dreaded delam issue on fiberglass rigs. We bought ours in December and have camped 3 weekends so far. Everything has worked great so far.
That price sounds pretty good. See if you can get a pressure test? Also, make sure you like the layout. Good luck!!
2002 27PBS Holiday Rambler (Aluminum sided/roof) Love it!
Previous RV's
'94 Jamboree 22ft. (This beast had a 460 with tons of power)
'95 VW Eurovan camper (5 cyl. dog) Pulled a 3 rail fine though.
Tent
Borrowed folks '84 VW Westphalia (water cooled)
Westronics
Redmond, WA
Posted: 03/11/12 08:53pm Link  |  Print  |  Notify Moderator
This probably has a rubber (EPDM) roof - the most common type.
The floor plan is quite similar to ours. and we love it. Good luck and good RV-ing!
When we were buying in 2003, this one made our short list.
2002 Jayco Greyhawk 24SS, Camera, ScanGauge, Inverter, Airtabs, Portabote, SeeLevel II, Tireman valves, Xatnrex Battery Monitor, Aero-flo vent, Trik-L-Start, XPS Rib, Chains, Lil' Stanker, Be kind to septic systems Ford: 1-800-444-3311. RV Tires
dobbler98
Ohio
Posted: 03/12/12 01:27pm Link  |  Print  |  Notify Moderator
Most of us use Eternabond tape to seal the roof.
Eternabond
1993 Minnie Winnie
Class C 24'
Chevy 350
Usually pulling one of my toys
Coach-man
Posted: 03/12/12 03:57pm Link  |  Print  |  Notify Moderator
nagel wrote:
The E450 is good. Slides? Important thing is that is has a floor plan you like. The other very important thing is that it doesn't leak. Check for leaks and then check some more. The cabover is critical for leaks, check this are very closely. Very costly to repair.
Snagel
X2, X2, the most important thing about any RV is the floor plan, will it support YOUR
lifestyle? Price is a close second, but if something does not work for you no amount of money later on will change that, and that problem will be with YOU, as long as you own the RV!
LMcq
Home
Posted: 03/12/12 12:29pm Link  |  Print  |  Notify Moderator
Great feedback everyone! Thank you for the info on the aluminum roof/siding. Does anyone know what you do to seal the roof? Does anyone know if there is more outside storage in the HR vs other with similiar floorplans?
Holiday27
Gresham, OR.
Posted: 03/11/12 10:34pm Link  |  Print  |  Notify Moderator
Pretty sure it's an aluminum roof like ours, although it's not the same year it's kind or Holiday Ramblers signature.
