RV.Net Open Roads Forum: Toy Haulers: Upgrading 16" China BOMBS to 17.5" Wheels/tires???
Search only in Toy Haulers
 > Upgrading 16" China BOMBS to 17.5" Wheels/tires???
captjohn57
Bay Saint Louis, MS
Posted: 03/25/12 06:45pm Link  |  Print  |  Notify Moderator
215/75. 4806# rating at max pressure. Guess I'll decide on the 16" or 17.5" when the trailer come in next week. The 16" 614's are probably good enough but we'll see. = )
'13 Voltage 3905 Epic Pkg, Loaded, w/Full Body Paint, 7 Goodyear G614 @110PSI and a China bomb 2nd spare
'08 Chevy 3500 D/A LTZ 4x4 CC Dually
'08 Saturn Sky Red Line- Rides in the Back =-}
'06 Honda 500 Foreman
'10 Custom Club Car Golf Cart- Black n Tan
joebedford
Jasper, Ontario
Posted: 03/25/12 07:28pm Link  |  Print  |  Notify Moderator
jackxclan wrote:
factory 3500#+
tires.
I don't think you'll be getting 3500#+ tires from the factory - closer to 3100.
Oh, I take that back - I got a flashlight and looked at my Mastertracks - 3520 at 80psi.
In my defense - it's 3072 in dually applications.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
captjohn57
Bay Saint Louis, MS
Posted: 03/25/12 08:01pm Link  |  Print  |  Notify Moderator
joebedford wrote:
jackxclan wrote:
factory 3500#+
tires.
The rep told me the axles and tires were 7000# rated. Not sure I believed him but now I guess I will = )
joebedford
Jasper, Ontario
Posted: 03/25/12 08:05pm Link  |  Print  |  Notify Moderator
captjohn57 wrote:
joebedford wrote:
jackxclan wrote:
factory 3500#+
tires.
I crawled under on another occasion - I think I was installing chocks for the motorcycles. I took the opportunity to check the axles - they had a label that said 7000lbs.
captjohn57
Bay Saint Louis, MS
Posted: 03/25/12 08:31pm Link  |  Print  |  Notify Moderator
Murgatroid wrote:
So, if a rim is stamped for 3960lbs, does that imply it can handle 110psi? Just curious.
-steve
Yes, I'm sure it will but the PSI should be stamped on the wheel. I've seen some G rated ST tires rated at 110 PSI and 3750# and some F rated tires 95 psi and 3950#.
Weird, I know. "F's" higher load than "G's"
cbmiller
Morgan, Utah
Posted: 03/25/12 09:41pm Link  |  Print  |  Notify Moderator
After I found out what the weight rating is for my wheels. I was able to find the same wheels on the internet and confirm that they are rated for 110 psi. And if you think about it, it makes since. If you have a wheel that is rated for 3960 lbs, it would have to except a tire equal to that weight rating. Therefore one tire that would meet that high of rating is, a "G" rated tire, and it has a max psi rating of 110 psi.
