RV.Net Open Roads Forum: Truck Campers: Camper tie-down questions
 > Camper tie-down questions
David Mo
Alameda
Posted: 03/11/12 08:35am Link  |  Print  |  Notify Moderator
I am going to be purchasing a Palomino Bronco B1251SB and putting it on a 2007 Dodge RAM 1500 short bed with a rear cab.
The dealer quoted me $800 for parts and labor for a tie-down. Does this price seem reasonable?
From what I have seen, tie-downs look pretty much like a bolt on device which means no welding or drilling of holes in the frame? Is this correct?
I am pretty mechanically inclined so could I install one myself?
If so, do you have any recommendations for my particular camper and vehicle?
Thanks,
David
David Mo
Alameda
Posted: 03/11/12 08:38am Link  |  Print  |  Notify Moderator
Also, I am competent enough to drill holes if necessary, but I am not a welder.
covered wagon
Posted: 03/11/12 09:40am Link  |  Print  |  Notify Moderator
Once you get into doing it yourself (not hard) you will probably do a better job.
The dealer set up my truck too and I had to redo some of it. They even had the charging wire not stripped and crimped into the electrical connector that way.
Watch that you can still open your fuel cap from the tie downs, if you can.
Specularius
Deville, La
Posted: 03/11/12 09:03am Link  |  Print  |  Notify Moderator
Get a set of Torklift's from Tweety's.com for $389 with free shipping. I put a set on my ford yesterday. No drilling and I worked very slowly and still did it in 2 hours. Very easy to install.
2011 F-350 DRW 6.7 Scorpion Diesel Reese Ford Hitch
2008 Bristol Bay 3420
2006 Okanagan 117DBL
campn4walleye
Central WI
Posted: 03/11/12 09:06am Link  |  Print  |  Notify Moderator
DH just put the tie downs and the super hitch (Torklift) on the new Dodge. He was amazed at how simple it was. You might have to read the directions several times. Also, one tip: print out the larger pics on Tweety's site. They are really helpful. That's where we purchased ours and the price was great with free shipping! Saved us over $600!!!!
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
kerry4951
East Central Pennsylvania
Posted: 03/11/12 09:23am Link  |  Print  |  Notify Moderator
Check out radauto.....they are cheaper than tweetys and also have free shipping. About $20 cheaper on 4 torklift tie downs and $110 cheaper on the torklift hitch/truss system.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
Dragonfly
Ohio
Posted: 03/11/12 10:01am Link  |  Print  |  Notify Moderator
DAVID MO
See the two or three recent threads on heavy duty half tons and light campers. Or Personal Message me for details. Some new options on a heavy duty F150 can get you 2400-3200 lbs of payload. Even with that payload, I will be pushing it with a light 14-1700 lb dry weight camper (I am still in the process of choosing one).
Your older 2007 truck most likely has nowhere near that payload so you may be very overloaded. If so, you still may be able to pull it off with a pop up camper and/or by dropping a wet bath and other weighty options.
Good luck
DRAGONFLY - F-150, 4WD, extended cab, long bed, Ecoboost engine, max payload & tow pkg, 17", 7 lug wheels, 10 ply "E" tires, upgraded radiator, shocks & springs, transmission cooler, stabilizer bars, 8200 lbs GVWR, payload 2,280 lbs, 21/16 mpg unloaded.
Photog101
Garden City, Michigan
Posted: 03/11/12 10:35am Link  |  Print  |  Notify Moderator
David Mo wrote:
Thanks for the answers.
Someone in another forum is telling me that since this is a quarter ton pickup, (the Dodge RAM 1500) that my capacity is 500 pounds and that the 1608 pound camper would overload my truck.
Is this correct? I have been looking all over Google for the cargo capacity of my truck but have been unable to find the answer. This person is telling me I need a 3/4 ton pickup to haul this camper...since 3/4 of a ton converts to 1500 pounds.
My thoughts are that 1500 means (roughly) 1500 pounds of carrying capacity.
Who is correct?
Whom ever told you that you have a quarter ton pickup, needs to be thumped in the head. IF we still used the tonnage ratings, as we did back in the day, a 1500 would be considered a 1/2 ton any ways.
There is still a whole lot more to figuring out what you can and can not haul. I am assuming (and I really hate to do that) from your description of your truck you have a mega cab. Try the specs below. Remember, that the advertised camper weights don't include water or propane ... OR your items for living, which could send your weights way up there.
2007 Dodge 1500 Towing guide
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
David Mo
Alameda
Posted: 03/11/12 09:46am Link  |  Print  |  Notify Moderator
Who is correct?
David Mo
Alameda
Posted: 03/11/12 09:47am Link  |  Print  |  Notify Moderator
Was looking for the edit button...found it
