RV.Net Open Roads Forum: Do i have an inline fuel filter?
 > Do i have an inline fuel filter?
tonym2180
davie
Posted: 03/11/12 09:17am Link  |  Print  |  Notify Moderator
I have a 82 winnebago with a 454...I replaced the inlet fuel filter on carb. Just wondering if it has an inline?would I have to remove fuel pressure and if so how? Any replies would be greatly appreciated. Tony
3708
modesto
Posted: 03/11/12 09:54am Link  |  Print  |  Notify Moderator
More than likely you do, check the inner side rail right behind the entry step, you will have a inline filter 1/2 inch in 1/2 inch out. 3708
tonym2180
davie
Posted: 03/11/12 10:11am Link  |  Print  |  Notify Moderator
Do I need to releive fuel pressure it does have a second electric fuel pump but it only works on a switch it is not on all the time?
sjholt
Henderson, NV
Posted: 03/11/12 10:24am Link  |  Print  |  Notify Moderator
Works with switch on.
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
tonym2180
davie
Posted: 03/11/12 10:31am Link  |  Print  |  Notify Moderator
Thanks for the correction
rvrepairnut
bc
Posted: 03/11/12 11:33am Link  |  Print  |  Notify Moderator
these systems use a fuel return line so no pressure to worry
I use to block the fuel return line on these units to help boost fuel pressure as they were bad for vapour lock and dieing out on hard long pulls.There most surely is a inline fuel filter somewhere on the DS frame rail
