RV.Net Open Roads Forum: Fifth-Wheels: air pressure
 > air pressure
BrokenElbow
Valencia, CA
Posted: 03/11/12 11:09pm Link  |  Print  |  Notify Moderator
If you check with your tire manufacturers web site, you will find a chart of psi for weight ratings for your tire. This chart will indicate the psi for the load on the tires. This chart for my tires indicated that the max indicated on the door jamb is appropriate when I am towing and that 50psi is fine for front and back when I am not towing (back of the tv empty). I usually go with the chart psi + a safety factor.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
 > air pressure
