RV.Net Open Roads Forum: General RVing Issues: New surface "driveway" for camper
 > New surface "driveway" for camper
batman99
at seasonal site
Posted: 03/13/12 08:53pm Link  |  Print  |  Notify Moderator
Yes. 4-6" of gravel, then 2" of 3/4" crush, then lay 24"x24" patio stones on its top. Add some good top soil around it, throw down some grass seed and within 4 months, it looks perfect.
re:
Ole Man Dan
Gadsden, Alabama
Posted: 03/13/12 09:16pm Link  |  Print  |  Notify Moderator
I had access to several thousand old bricks. I put them down and swept
Mortar mix into the joints. Rain drains toward the road.
Not really pretty, but effective. (Did I mention FREE bricks)
Father-In-Law was a contractor and brought the old bricks to the rear of his property after jobs...
wbwood
Mooresville/Troutman, NC area
Posted: 03/13/12 09:52pm Link  |  Print  |  Notify Moderator
Anyone have something put in besides asphalt or concrete that was on a slop and hadit built up on side?
Not sure if you can tell on the right side of this picture much (only picture I could find right now, but I have slight slop on the side of my house, it slopes less the further back you go. Starts off big at the top of the driveway (where I was when I took this photo).
To give you idea of how much slop there is, here is a picture of the back deck. From the front of the house to back deck it drops that much. But from about the edge of the back of the house it slopes just a little.
When I parked camper beside house it only extended forward of the back end of the house by about 6-10 ft. with the tongue jack all the way down, if I could put the rear tires up off the ground maybey 6-12", then it would be level.
Brian
RVing Illustrated
2013 Thor Chateau 31L
davelinde
Lake Nona, Florida
Posted: 03/17/12 08:03pm Link  |  Print  |  Notify Moderator
Ours is in now. Asphalt millings.
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB HO-CTD/48RE
01 Volvo VNL660 singled VED12
09 Heartland Cyclone 3210
mudmaker
Iowa
Posted: 03/17/12 08:41pm Link  |  Print  |  Notify Moderator
Would have liked millings, but we didn't have any. (I work at the local quarry) I built a wall to take up the slope in the yard and filled most of the space with some left over septic stone and then covered the whole drive with 3/4 roadstone. After a couple mild showers it packed hard and I have the slope that will get rid of the rain. So far it's great.
Glen and Loretta
Marc, Jake, and Kirsten
Keystone Cougar 326MKS
2013 GMC Terrain
12 Silverado 3500 SRW quad 6.6 Dmax
03 Dodge 3500 DRW quad 5.9 cummins
Yamaha EF2400is gen
davelinde
Lake Nona, Florida
Posted: 03/17/12 08:47pm Link  |  Print  |  Notify Moderator
I've had bad experiences with bluestone in NJ - basically it just kept sinking away - we've topped that driveway twice now. Even though FL is all sand, the neighbors have a 1/4 mile access road all done in millings and it has held up fine. We put down about 3" for the RV pad and our driveway. Unfortunately the county noticed and made us rip out the apron that connects to the public road they require 6" of millings over the entire right-of-way.
So... we will get to see how 3" base holds up compared to the 6" base over time.
wbwood
Posted: 03/19/12 03:32am Link  |  Print  |  Notify Moderator
How big of a wall did you build up. I had one guy a couple years ago come out and was talking about putting in all this stuff...and doing a block wall and tying it in to the foundation of the house...I was just thinking a couple railroad ties high and filled in. he said the weight wouldn't hold on it.
I even though about building basically two ramps with hard packed dirt or another materail about a foot tall and big enough for the double axle. My only issue would be the stabilizers that hang down...
mudmaker
Iowa
Posted: 03/19/12 05:05am Link  |  Print  |  Notify Moderator
I went three rr tirs high at the back and for most of the length of the camper. Drilled half inch holes and pinned them with 18 in. sections of rebar. Then tied them together with foot long lag bolts. Oh, and I burried the first tie in the round about half it's hight. On the back all I did was cut one in half, tie it into the wall at 90 degrees and bury it so it was level. Then pin and bolt another full length one on top. Thought about running ready bolt thru horizontally and mounting flat plates and then burying them to prevent blowout of the wall. I couldn't kick or push the wall over tho with what I had done so I just threw in the septic stone and covered it with 3/4 class a roadstone. Seems pretty firm right now. We'll see.
Mootpoint
Somewhere in North America enjoying the life!
Posted: 03/19/12 11:21am Link  |  Print  |  Notify Moderator
re:
I did similar to this but used the concrete blocks that have holes in them to allow grass to grow in the blocks. They are used around here for fire equipment access around apartment blocks. Looks like the yard is all grass until you get right on top of it. Crushed rock for a base then lay the blocks. Sweep dry top soil over the top several times wetting down in between. Plant grass seed and care for it as normal. It does require a bit more watering in summer for the heat that can be held by the concrete can dry it out. I also tracked mine right to the road so there is no wheel marks if it is wet.
Nothing sucks more than that moment during an argument when you realize you're wrong.
Jayco25E
PA
Posted: 03/19/12 12:45pm Link  |  Print  |  Notify Moderator
I had blacktop millings in my driveway and the thing I hate about them is if they get tracked in your house or RV they leave tar marks on the floor. But besides that its the best thing from blacktopping your drivway.
2008 Chevy Avalanche
2005 Jayco 25E HTT
2 retired Greyhounds
