RV.Net Open Roads Forum: Class A Motorhomes: Fuel pump 96 F-53 chassis (Ford)
 > Fuel pump 96 F-53 chassis (Ford)
Page of 9
donandmax
Delta Co.
Posted: 03/11/12 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have read numerous complaints about this model year in tank fuel pump, They have a tendencey to stop working.. Does anyone have one that they have never had problems with or know anyone who hasnt had a problem ? My Damon was bought when it was 15 years old (from dealer) so I cant get in contact with previous 2 owners, (who by the way appeared to have taken excellent care of this coach) to find out if they ever replaced it. The 460 engine runs like a new one. It has 37,000 mi on it and so far no problem, Just asking if these pumps are a sure thing to go when least expected...
BobR
Aurora, Illinois
Posted: 03/11/12 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
My fuel pump failed in 1992 at 16,000 miles. The replacement (Ford) has run fine for the last 20 years. Mine gave warning signs of the idle surging on start up and running rough as if I had gotten bad fuel. Every so often, I will listen to the pump. If you notice a change in pitch at idle, then I would be very observant of how the engine is running. Personally, I don't think everyone needs to change out their fuel pumps. Several people feel keeping the tank above 1/2 will keep the pump cool and prolong its' life.
dsbsi
Minnesota
Posted: 03/11/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
(copy corrected 3/12/12)
Ford installed the improved style fuel pump in F53 production built after 6/30/97.
Ford Tech. Service Bulletin No. 97-23-9 provides the part numbers required to install the new style Pump/Sender in F53 Fords built before 7/97.
F6PZ-9H307-DA New Turbine Pump/Sender
F7PZ-9A213-BA Jumper Harness (Chassis Built 1989 - 11/26/96)
F7PZ-9A213-CA Jumper Harness (Chassis Built 11/27/96 - 6/30/97)
* This post was edited 03/12/12 09:34pm by dsbsi *
Dwight
1995 Ford F53 Bounder 35U
Cold Spring Minnesota
Big Katuna
Deland, FL
Posted: 03/11/12 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
A service manager at a Ford truck center told me this. The original pump was ok for the chassis when it was a short fuel line from the tank to the engine. Then they kept stretching the chassis and the pump couldn't keep the pressure high enough. The engine and ECU expects to see the PSI in the high 30's. If it drops below 32 PSI or so, the ECU goes wacky. When they put a guage on mine, it was in the low thirties. When its hot and you are going up a mountain at wide open throttle, it couldn't deliver in my 35' coach.
So you should be able to have a mechanic either put a guage on the fuel line near the engine and check it (under full load hot). I think the later OBDIs reported fuel pressure PSI.
My Kharma ran over my Dogma.
stew&Jan
Lanesville, IN
Posted: 03/11/12 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Our 1995 went out at 45K. I suggest finding a good time to replace it because if it has not been replaced before you will be replacing it soon
Jerry B
Lake of the Ozarks
Posted: 03/11/12 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Mine went out at 47K miles. Replaced only the motor/pump, not the entire assy.
Jerry B
Mobile Suites 36TK3
dsbsi
Minnesota
Posted: 03/11/12 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
1995 Ford F53 35'Bounder
1999 Bought New Style Fuel Pump/Sender - (kept it in a luggage compartment)
Drove to Alaska 2 times and Nova Scotia once (slight vapor lock)
2007 50,000 miles (Vapor lock worse (change fuel pump/sender myself)
2009 70,000 miles (West Coast and the highest passes [10%] I could find and did not disconnect the toad)[no problems](Next time I'll disconnect the toad on 10%grade to help the engine and transmission live longer)
* This post was edited 03/11/12 07:04pm by dsbsi *
dsbsi
Minnesota
Posted: 03/11/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
How did you replace only the pump/sender? Dwight
FuzzyKnight
Santee, Ca
Posted: 03/11/12 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
MY 1994 Pace arrow has 36000 miles on it an I just replaced the pump as it was only putting out 20PSI. Used the new and improved pump and all is well.
Fuzzy and Mary
1994 Pace Arrow 33
1928 Model A
1953 Ford Club Coupe
1963 1/2 Falcon Ranchero Original factory V8 4 spd
1963 Fairlane SportsCoupe
1965 Honda SuperHawk
Mr. Jeff
Edmond, OK
Posted: 03/11/12 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
The original on ours was replaced at about 75k miles. The current pump has 132,000 miles on. Drive yours often so the seals don't break down and it should give you good service for a long time.
Jeff, Leslie & 4 wonderful kids
2000 Allegro Bus (37,000 miles)
1994 Fleetwood Southwind (212,000 miles and going strong!)
F-53 Chassis, F-460 (Original and nothing special!)
22' MacGregor, Hobie 16, Sunfishes
Page of 9
