gottogogary
georgia
SOMEONE POSTED ABOUT VIBRATION ON REAR WHEELS ON THERE F250.HAD NEW 18 IN MICHILEN TIRES INSTALLED.AT ABOUT 45 TO 50 MPH BACK VIBRATES BAD.HAD THE TIRES BALANCE 2 TIMES .CARRIED IT TO THE FORD DEALER THEY SAID THE STIFF SUPENION AND 80 LB OF AIR WAS CAUSING THE PROBLEM .WHEN PULLING A LOAD SEEMS TO RIDE BETTER.ANY ADVICE.
jasult
Central NJ
I just repaired a vibration on a 2005 Super duty for a friend. Dealer said it was nothing but when I drove it i knew what it was. It was the hanger bearing on the rear driveshaft. But this was a vibration not a stiff ride
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1996 F250 Powerstroke, Baby Swamp injectors,BTS Trans TW Chip,210,000 miles,
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
Pete_k
Stantonville Tn
Look and see how much weight they have on it. Sounds like a bad tire and they have 7 or 8 oz of weight on it to try and get by.
My Toyo's were like that and now with the Beads inside the tires it a lot better.
If I have the air up there for a full load they do good. But drop the air pressure down for the empty ride and its unreal how bad they shake.
You can bet the next set of tires will go back and they will trade them out. This set I was in bed with my back for 3 months after getting them installed so it was my fault.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
kab449
PA
Rotate the tires and see if the vibration moves or stays the same. If it stays the same it is not the tire/wheel assembly and you will have to look at the drive train.
2011 F250 Lariat,SRW,Crew,6.7TD,ShortBox
2012 Montana 3750FL
Reese 18K Elite/Hidden Rails
sirdrakejr
Las Vegas, Nevada
Moved from 5th wheels to tow vehicles.
Frank
Charlie D.
E. Texas-Orange
Chock the wheels, jack up the rear and put it in drive. Thought I had a carrier bearing bad but found a tire out of round because of a broken belt.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
spud57
Stratford PE
I have a 2008 F250 and I have that. It goes away with the 5th wheel hooked up. It is a characterstic of most F250/350s. Go to ford-trucks.com and you'll read lots of threads about it. Most can't get rid of it. Some have tried new heavy duty shocks or air bags. I had my tires road balanced, rotated and air bags put on. Didn't dissappear. It is a combination of a specific speed and a frequency thing. I've learned to live with it.
S
edited 03/12/12 06:43pm by spud57 *
2008 F250 XLT 4x4 SC LB V10
2010 Outback 321FRL 5th wheel
SoCalDesertRider
SanDiego, CA, USA
Drop your rear tire pressure to about 50 psi and the rough unloaded ride will soften up. Air them back up when you load it back up.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
