kwlincoln
North of Houston, TX
We are camping WAY off the grid and our backup generator is failing us! It will run fine for about 20 minutes and then it starts idling up and down and up and down, then shuts off. After it fully cools down, it will run again, but after 20 minutes, does the Mae thing again.
Oil is fine. Seems to do it when it gets warmed up.
What could it be?
edited 03/12/12 09:18pm by kwlincoln *
conmoto
Northern Illinois
Try applying the choke halfway,they get finicky when the carb gets a little dirty.
snowpeke
Nevada City California
Make sure that the knob on top of the gas tank is on. If it's off it will cut out in 15 to 20 min.
2002 Chevy DuraMax
2003 Sprinter 5th wheel
One Black Pekingese
One party color Pekingese
kwlincoln
Carb was thoroughly cleaned and know on gas cap is on. I hope it is something easy but need more suggestions.
Mont G&J
Missoula, MT
snowpeke wrote: Make sure that the knob on top of the gas tank is on. If it's off it will cut out in 15 to 20 min.
Agree...For some reason the vent on the gas cap may either be plugged or not in the run position. Your problem as you describe it is what happens when the gas tank is not vented.
MrWizard
Traveling
moved from technology corner
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
Jersey Shore
Jersey Shore
Try running it with the gascap open slightly and see if it stays running. If it does, the gascap is not venting.
Just had a similar problem here. Would run for for 15 seconds to a few minutes and shut down (without surging). Sometime it starts back up, sometimes not (no spark). Traced it to a faulty ignition coil with the multi meter. Yours surges before shutting down so it sounds fuel related. I've forgot to open the vent and it does that.
Good luck and let us know what the fix is.
'06 Ford F-350 6.0 CC LB SRW
'04 Holiday Rambler 37CK Toy Hauler
Trailer Trash 2
Santa Fe Springs, CA
Ditto on the air relief on gas cap. thats what happened to me.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
jasult
Central NJ
I say it is the hidden pilot jet that is clogged. Very common problem that is over looked by most people that clean out carb.
Could also be dirt in bottom of tank or fuel line partial clog and after setting a few minutes the fuel bowl gets refilled until you run it again
Honda carb
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1996 F250 Powerstroke, Baby Swamp injectors,BTS Trans TW Chip,210,000 miles,
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
ng2951
Louisiana, USA
I too would check the cap vent. If it will run for 20 minutes, I think I would run some carb cleaner through it too.
Whatever the problem is, it sounds simple.
Foard County News & Sassy Schoolmarm
with Lady & Chloe
2012 Unleashed 27SBU
2013 10 days camping
2012 50 days camping
'07 GMC Sierra 2500HD Classic 4x4 LBZ Duramax Diesel
Honda 2000sThe Bayou Bounty Hunters Cowboy Club
The Single Action Shooting Society
