RV.Net Open Roads Forum: Travel Trailers: Fender Skirt crack
 > Fender Skirt crack
LarryJM
NoVa
Posted: 04/02/12 04:47pm Link  |  Print  |  Notify Moderator
What I finally did was ordered some 12x24" sheets of ABS in a couple of thickness and whet to a plumbing supply house and got the Oatley real ABS cement that has dissolved ABS in it and reinforced some cracks and the four wing nut holes in my molded propane cover with the sheets of ABS. Don't use the universal cement like you can get from Lowe's/HD since it doesn't have ABS dissolved in it. Following is what you need and might be available at your local RV dealer.
By using the ABS sheet and real ABS cement you can make it stronger than it was originally with a lot of support across a break or large crack.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
rrev
Beatrice, NE
Posted: 04/02/12 09:18pm Link  |  Print  |  Notify Moderator
Looks like they turned out pretty good. Give them a quick coat of paint and you should be good. Glad I could help.
LVJJJ
NW WASHINGTON
Posted: 04/09/12 05:01pm Link  |  Print  |  Notify Moderator
DE88ROX wrote:
LVJJJ wrote:
brirene wrote:
For smaller cracks, drilling a hole at the bottom of the crack, slightly larger than the crack, has kept mine from cracking further for the past 4 years and several thousand miles.
This also works good to keep that crack in your windshield from spreading.
Drilling a hole in your windshield?
Just sorta kidding (April fools maybe)?
1965 CHEVY VAN, 292 "Big Block 6"
1985 WILDERNESS 3000CL
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
