RV.Net Open Roads Forum: Travel Trailers: My "Level" Best!
 > My "Level" Best!
Page of 7
Jacksons
columbus,ohio
Posted: 03/12/12 08:54pm Link  |  Print  |  Notify Moderator
Gee, we have a rear bedroom, so I prefer to have the trailer slightly lower in front, and the right side slightly higher than left so water on slide out runs away from trailer.
Sinecure
South of New Orleans
Posted: 03/12/12 08:58pm Link  |  Print  |  Notify Moderator
To each his own. I camp to relax, not to spend gobs of time trying to level my trailer. If anything I try to slightly lean to the drivers side so that condensation from the AC doesn't drip on the awning side, making a puddle.
2007 Wilderness 3102BDS Travel Trailer
2006 GMC Sierra 2500HD 4x4 LBZ Duramax Diesel
afraid of bears
Prince George Area
Posted: 03/12/12 09:08pm Link  |  Print  |  Notify Moderator
Old-Biscuit wrote:
I know this post sounds harsh.....but come on, just a little bit of common sense.........where has it gone
You must remember, we now live in an "It's not my fault." society. As a result, it is no longer our responsibility to learn how to do things. If one cannot do something properly (using common sense), it's not one's fault. Hence, it is the dealers' fault that trailers are unlevel.
LOL
rrev
Beatrice, NE
Posted: 03/12/12 09:30pm Link  |  Print  |  Notify Moderator
So how far out of level is ok as far as the refrigerator goes? I like the idea of have a little slant to get the condensation from the AC off and not down on the slide out. Plus, I'm used to sleeping with the head of my bed up higher than the bottom due to the DW having acid reflux really bad.
12thgenusa
Lakewood, Colorado
Posted: 03/12/12 09:59pm Link  |  Print  |  Notify Moderator
I remember when I bought my first 5th wheel. I asked the dealer about some bubble levels. He said "Oh, you're one of those" in a rather sarcastic manner. I'm not ashamed to admit, yes, I am!
Doesn't take but a few extra minutes and makes the use of the trailer more enjoyable.
Dave & Gean
2007 Tundra DC 4X4 5.7
2009 Cougar 245RKS
370 watts ET solar
Rogue 3024 MPPT controller
440 Ah battery bank
ProWatt 2000 inverter
FLY 4 FUN
Alberta
Posted: 03/12/12 11:26pm Link  |  Print  |  Notify Moderator
First thing I buy for each new unit. My sister still insists that a can of coors light on its side works just fine!!
I prefer levels
Daryll
2009 Colorado 29BHS
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
Prodigy BC Reese 16K slider
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
DE88ROX
West Michigan. The other West Coast
Posted: 03/13/12 06:47am Link  |  Print  |  Notify Moderator
Actually it only takes all but 2 minutes. I learned this when I had my PUP. I had stick on levels on the front of the trailer. When I backed into my site the first thing I would do is check the side-to-side level. Throw the appropriate sized boards down then back the trailer on top. waa-laa!!. I would set the front-to-back level easy enough with the tongue jack.
I used to see so many people try and level the trailer AFTER they unhooked, using their jacks. They didn't know that their main purpose was to stabilize, not support the camper.
Im real fussy about things like that. I once tore out an entire length of a middle shelf (i built 3) and re-did it because it was off a 1/4" in the span of about 4' because everytime I would see it it would drive me nuts!!!
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
WHS
Waitsburg, Wa.
Posted: 03/13/12 08:59am Link  |  Print  |  Notify Moderator
DE88ROX, you said it best. It does not take too long to get the basic level, then use the "stabilizers" for fine adjustment.
Personally, setting up camp is part of the fun for me. I enjoy getting things just so, from making sure I am in just the right spot, checking awning deployment (trees, can I sit under it, etc...), low spots (water accumulations), to getting the trailer level. When you primarily boon dock, getting in the right spot can really make a difference. Seriously, just pulling in and then finding out the next day that your entrance is right over a big puddle... Not much fun. Plus, I enjoy sitting at my dinette with the big window and enjoying the view, so why not make it the best view possible.
HC
skip
05' Layton Lite 170LT Cascade edition
06' Chevy Silverado K1500
We-No-Nah Rendevous, a Ljutic, a Remington, a Hard Rock Pro, a Polaris 550XP & Raleigh the Hunter
AtomicChicken
Central Louisiana
Posted: 03/13/12 09:03am Link  |  Print  |  Notify Moderator
I see the same thing all the time as well. Seems like it would be one of those common sense things - if for nothing else than to be comfortable when in the trailer.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
fastpete
Somewhere in West Texas
Posted: 03/13/12 10:02am Link  |  Print  |  Notify Moderator
After I get parked in my site, level my trailer, get all hooked up, then take a walk around the campground, I might notice other units that are not exactly level. I then return to my trailer, get out the lawn chairs, extend the awning, set up the grill, pop a cold one, and usually by then, I a have ceased to worry about other peoples set up. I usually will not be stressed out and or spend to much of my relaxation time thinking about someone elses trailer not being leve. I will probably not lose a lot of sleep over it. Just my thoughts on this topic.
Page of 7
 > My "Level" Best!
