45Ricochet
North Idaho
Here's another Capt, if your route is this direction.
Another
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
me2
Wherever
Update.
I put about 1200 miles on my truck since the new fuel system was installed. It seems to run much better. Its certainly a lot smoother and quieter.
However, this morning, going down the freeway it smoked out the cars behind me. Thick blue smoke and lots of it.
I'll contact the dealer tomorrow.
45Ricochet
North Idaho
Regen are complete? Any re flash's done last week? They pulled your HPFP IIRC and everything looked clean? No injectors were pulled?
Blue smoke as you know is raw fuel. I assume you have checked the coolant and oil creep.
Hope its only a re flash but....
me2
Wherever
rick83864 wrote: Regen are complete? What do you mean ?
Quote: Any re flash's done last week? None on the work order.
Quote: They pulled your HPFP IIRC and everything looked clean? No injectors were pulled? They found shavings and replaced the entire fuel system.
Quote: Blue smoke as you know is raw fuel. I assume you have checked the coolant and oil creep. Raw fuel is white. That is what it used to do. Now it has a blue haze. Coolant level is down. Maybe it left the shop that way, but I doubt it. I didn't check the oil level.
I had an incident with the air cleaner plugging with snow while driving in a storm since it was fixed. I actually suspect it needs a new turbo now.
Quote: Hope its only a re flash but.... Thanks.
For anyone reading this, its a full time job owning a used Ford diesel truck. Definitely not for the faint of heart or anyone needing a reliable vehicle, day in, day out.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Again why buy one then? I'm sorry but if I felt that way about any vehicle it would not be in my driveway! Oh wait I do feel that way and yep I feel that way about Ford's. Maybe that is why they no long grace my driveway.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
me2
Wherever
Update. Dealer says the truck is in a long regen and that when its doing that and its cold in the morning, it will smoke blue.
Dodgeboy, I have a Ford because its getting a Cummins. I planned this from the day I got the truck and I'll be carrying through with that plan.
The efforts I've made with the 6.4 thus far are merely to keep it running until I do the swap. Having said that, I am SHOCKED at what it takes to keep a 6.4 running.
This has been a very good lesson for me, because now I will never doubt if I should have done the swap or not.
me2
Wherever
Not my truck, but still relevant.
http://powerstrokenation.com/forums/showthread.php?p=1819412#post1819412
ib516
Up here!
me2 wrote: Not my truck, but still relevant.
"Thou shall not tune a 6.0L or 6.4L Ford diesel engine and expect them to last". Expensive lesson.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
45Ricochet
North Idaho
Wait aren't those guys at Magtech and Madd ex ford software engineers?
They had those engines maxed out and then some from the factory. Can't let the little red headed step child beat us mentally at Ford. Compare the hot tuned PSD 6.0 to the VT365 in longevity. Navstar got screwed IMO. But what the heck, the 6.0's create jobs here in the USA.
me2
Wherever
FYI, my dealer has 3 new 6.4 engines in shipping containers waiting to go into trucks this week.
